Bros. Ano kaya problem pag nagaaccelerate ka tapos medyo kumakadyot yung engine, hindi smooth yung acceleration nya, then check engine na sya. Once i use it again ok naman sya, wala na check engine. Hindi naman madalas to pero worried lang ako.
I'm using Ford Escape 05 AT
best route would be have it diagnosed using a code scanner so you'll know if any sensors or system is having problems... from that you can probably know which things to fix
Umiilaw mostly ang "check engine" warning light pag ang problema ay related sa exhaust/emission control, and possible causes may include faulty spark plugs, high tension wires/cables, lambda/oxygen sensors, barado catalytic converters, may air leak sa intake manifold system at kung kinakapos din ng fuel supply. Since may kasamang jerking o kadyot during acceleration, a visual check of the above may help otherwise have it scanned for stored DTC's in your engine control unit...
same problem, corolla ko medyo nagkakadyot din sya lalo na pag ung temp nya eh di pa umaabot up to mid range, wla naman check engine, dun lang kaya ung sa air filter, oil filter at engine oil ko na 2 years nang di napapalitan?..
