Results 41 to 50 of 77
December 13th, 2005 01:27 AM #41
*woodfire, di ba may EFI na bolt-on kits para sa engine mo?
December 13th, 2005 08:22 AM #42Originally Posted by niky
what i did was just to install significantly better parts like a new generation carburetor, better breathing aluminum cylinder heads, intake manifold, larger intake and exhaust valves, ceramic coated headers, etc...
December 13th, 2005 01:12 PM #43
3k dollars?!? Ngek. Puwede ka nang magpa-supercharge nun, diba? Still, an interesting mod for hot-rodding, though. I've always felt that it's the looks and the spirit of the car that count, not the originality... but then, ang sarap ng glug glug glug ng old-school set-ups.
December 14th, 2005 09:56 AM #44Originally Posted by niky
hehehe exactly! the glug glug glug and the broooom broooom of the old school V8 exhaust system (tri-Y H-pipe dual exhaust) is exactly what I'm looking for in a classic car. My wife is still wondering why I like such sound (which she considers annoying)... ahh women, they still don't get it, do they hehehe
- Aug 2003
- 9,720
October 22nd, 2006 07:39 PM #45bumping...me tatanong lang sana ako B)
i noticed a few setups with Weber/Solex side-draft carbs; tinatry ko hanapin ung air intake/filter, til i realized na wala nga talaga.
is this really advisable? aren't you risking long-term damage to your engine that way?
- May 2008
- 161
October 2nd, 2009 06:07 PM #46anu po ba ang advantages at dis advantages ng de-karburador at efi na makina??
October 2nd, 2009 06:30 PM #47
kamotecueman,
efi is the better solution to higher miles per gallon rating and air pollution reduction. with carburetors, we had hot idle compensator, high altitude compensator, early fuel evaporation systems, choke systems, throttle check pot or dashpot to name a few mechanical subsystems of the carburetor. most of them if not all had linkages that get stuck in time and needed to be adjusted. carburetor fed engines contributed to more carbon dioxide emissions, oxides of nitrogen, unburnt fuel and evaporated fuel from the carburetor float bowl. an act of congress passed in the united states called for increased mpg and lower evaporative and exhaust emissions. picture this, the efi systems involve computers to constantly adjust air/fuel mixtures to stoichiometric (14.7 pound of air used to burn 1 pound of gasoline). computers make all the adjustments which is very difficult to achieve if not impossible
jick
October 2nd, 2009 09:00 PM #48
EFI engines emits cleaner fumes, more responsive, and have better fuel consumption.
Carburetor-fed engines emits more carbon, less responsive especially in cold starts, and less efficient in mixing & burning fuels. That's why it was considered obsolete in the US and other countries during the early 90's.
- Sep 2008
- 1
October 3rd, 2009 09:25 AM #49
October 3rd, 2009 11:57 AM #50
As opposed to the finicky EFI systems of yesteryear (60s to 80s), modern 90s and up EFIs are very robust and easy to maintain. Most of the problems you will get are vacuum issues, which you can fix by patching hoses. Electronic ignition control also means that you won't have distributor caps breaking down on you, either.
