Results 1,091 to 1,100 of 1166
August 8th, 2022 10:22 AM #1091
Para sa akin, kahit may differences, parang pareho lang ang quality. Gusto ko sanang buksan pero wala pa ako sa ganung level hehe
For the Altis na canister type ang oil filter, ¾-16 ang thread size, so pwede ang BT223. Pwede rin B1405. Longer filters: B7172, B113, B243, B1416, B178.
For the Altis na elemet type ang oil filter (Toyota 4152-YZZA6), pwde Baldwin P7454..I think this is Made either in Taiwan or Korea.
Sent from my CPH1911 using Tsikot Forums mobile app
October 12th, 2022 06:13 PM #1092
Baldwin B33 side-by-side
Made in U.S.A. / Made in Mexico
Difference:
1) website;
2) "a CLARCOR company"
October 12th, 2022 06:17 PM #1093
Difference:
3) Made in Mexico has crimps;
4) Made in Mexico has smaller font size;
5) Made in Mexico has sharper characters/text
October 12th, 2022 06:20 PM #1094
Difference:
6) Made in U.S.A. has 11-digit manufacturing reference code)
7) Made in Mexico has 6-digit manufacturing reference code
- Jul 2009
- 2,618
October 13th, 2022 12:17 PM #1095
October 13th, 2022 12:59 PM #1096
Yes. As far as I know, BT223, B1402, B2 are now made in Morocco. B33 made in Mexico. BF1280 made in China. All these filters used to be made in US. Local importers have difficulty sourcing BT223 and B37. Donaldson P502008 in now made in Colombia..used to be made in Indonesia.
November 6th, 2022 01:59 PM #1097
New stocks BT223
Made in USA
Manufacturing date: July 19, 2022
Individual pack/box has new/different design/s. Texture of materials used similar with packs/boxes being used in other areas (i.e., Mexico, Morocco)
The filter itself is still the same.
November 6th, 2022 02:23 PM #1098
if it's ok to use non-oem engine oil filters on our vehicles, does it follow that using replacement atf transmission filters would pose no problems too?
November 20th, 2022 06:42 AM #1099
Canister filters are usually pre-oiled from the factory. There are times when packaging is damaged and the filter is exposed to heat, moisture, etc. Below is a 2020 filter with damaged shrink wrap, dust on the rubber gasket, and rust.
- Feb 2014
- 2,536
Saken sir Minsan NASA 2k stable mga 2to3 minutes mag up and down need pa re start para maging...
high idle RPM at engine start
