Results 101 to 110 of 754
June 5th, 2013 01:26 AM #101
Working red positive to dead red positive
Working black negative to the engine block of the car being started ( anywhere that there is solid metal where the alligator clamp can be attached)
Your main goal is to jump start the car, by doing the above you are effectively using the battery of your altis to start your corolla via the jumper cables. If you connect the poles, you are decreasing starting current from your good battery because your dead battery is in part absorbing it.
June 5th, 2013 01:27 AM #102
Wala ka namang planong tangalin ang battery mo habang umaandar ang kotse para malaman kung ok pa alternator mo, hence my post.
3yr old battery... Dagdag mo na lang yang pambili mo ng battery monitor sa bagong battery, wag mong hintaying mamatay yang battery ng altis palitan mo na yan.
Jumper cable is a must, so bilhin mo yan.
June 5th, 2013 01:32 AM #103
Ugali ko talaga intayin hanggang maubos yung battery, tawag motolite kung sa bahay abutan. Pag sa labas, tulak Pero this time nga ayokong intayin kasi iniisip ko bumili ng Amaron eh wala naman ata sila delivery. Pwede rin sa Casa ako bumili ng battery, ang galing kasi ng stock battery nila umabot ng 3 yrs. Yung motolite kasi right after warranty(18 months) namamatay na
June 5th, 2013 01:33 AM #104Originally Posted by Cathy_for_you View Post
working red positive to dead red positive
working black positive to deal black positive
May naalala kasi ako na may proper seqeunce e nalimutan ko na. Pati sa pag tanggal ng clamp may proper sequence daw
Tapos una ko sisindihan yung working car diba?
pula sa pula
itim sa itim
start!
that's it
June 5th, 2013 01:41 AM #105
June 5th, 2013 02:06 AM #107
June 5th, 2013 02:19 AM #108
BANNED BANNED BANNED
- Feb 2013
- 487
June 5th, 2013 06:51 AM #109
June 5th, 2013 07:58 AM #110
high idle RPM at engine start
