Parang pointless to have it charged for testing then tambak for spare. tatagal lang for diagnostics and your not even sure that spare is in good condition.
papunta ka na lang electrician diyan para tapos problema.
SUVs & trucks nas 150A ang starters, small cars below 100A. Gauge 6 250A will do.
Haha.. It will take some time pa para ma get over yung battery-problem theory.. Madami naiinip kung aandar ba yan.
If you want, i can initially check or tow your car if necessary. Toolbox in my truck can literally overhaul a car..lol just pm me details.
Im going south this afternoon baka madaanan. Maulan ba south, parang dumidilim.
I went to Motolite na. My 2SM was in stock too long puro red na pag check. Looks like I have to ask them to go to my house. Bakit dati pala ginawa ng Motolite pinagdikit lang yung battery para paandarin? Worst case scenario pa home service ko na
Sent from my GT-N7100 using Tapatalk 4 Beta
ah ok ... ayaw tanggalin yung LIVE battery ng Altis
but now marunong na mag-jumper ... yet ayaw umistart ang Corolla
baka kulang yung pag-charge (while jumpered) ... try jumper procedure again, make sure clamps are tight (at both battery terminals), let live car (Altis?) run on idle for at least 10 minutes to let the weak battery absorb charge more than before ... then while Altis is still idling, try starting the Corolla (at least 5 seconds each time) ... if 3 tries won't start the Corolla, there's engine problem (fuel, ignition, etc)
if the Altis' battery is not giving you problems yet (kahit luma na) ... it is still strong enough for the jumper procedure ... note that when idling, the battery is already being charged by the alternator ... and when jumpered, the alternator (of Altis) is also the one charging the weak battery (of Corolla) ... idling won't hurt your old (but still functional) battery at all
i suggested that while jumpered Altis is idling, try starting the Corolla ... this is to allow both Altis battery and its alternator to provide the momentary power for the Corolla ...
yes, the Altis battery may lose some charge during the few seconds of attempting to start the Corolla, but then it will immediately get recharged by the alternator as soon as you stop trying to start the Corolla (all the while the Altis is idling)
let me remind you that when jumpering, the clamps of jumper cable must be securely firm/tight on both battery terminals ... this will ensure that when Corolla tries to start, most of the power will be supplied by the Altis
a loose connection will impede power transfer from the Altis, causing the weak Corolla battery to supply most of the power for starting which may not be sufficient
yup... dapat hindi stock ang MF. kung ung none MF pwede pa cguro as long as huwag mo lagyan ung solution sa baterya.
eto na naman si ano...
baka daw naka-kambyo dumikit ang clutch di ma-i-neutral kaya di mapaikot ng starter ang makina
negative?
you're the one who's coming up with those negative scenarios
putol timing belt, stuck up ang makina, stuck ang clutch
di pa nga sigurado kung malakas ang battery or tama ang pag lagay ng jumper cable
you think you're producing results?
nasaan results mo?
pag pinacheck niyo kay jick makina niyo sigurado pati transmission, differential, preno... bubuksan niya lahat yan
palit mga sensor, wiring harness, ecu, wiper, radyo, tire valve, gulong...
cathy i-rule out mo muna ang battery
palitan mo ng battery na 100% sigurado malakas
huwag na jumper
di pa nga na-rule out ang battery gusto ng isa dyan ibaba ang makina at transmission
