Page 11 of 38 FirstFirst ... 78910111213141521 ... LastLast
Results 201 to 220 of 754
    Oct 2011
    #201
    hindi ba ganyan ang kalakaran sa rapide?
    Feb 2009
    #202
    hehehehe nobody has had heart attack yet?
    again, putting words in other people's mouth. palengke na naman.
    i did not recommend or suggest to open, replace, repair anything but gave ideas on how to check if indeed it was the battery or the engine. again, i did not order, recommend or suggest to repair or replace anything. the information given by the TS as she admits is incomplete and that she is not very good in describing the symptoms.
    #203
    Walandyo,- 200+ posts na pala ito,- and still going strong.....
    Tumakbo na ba, ha Sis?... (I read somewhere na for sale na?.... )
    19.5K:thatsit:
    ClaNker:
    Parang CASA pala yang si Jick, biglang dumadami sakit ng sasakyan. Mapapagastos ka ng di mo alam.
    Retz:
    hahaha
    damage control
    sige tuloy mo lang ang pagpost mo ng mga OA guesses mo para lalo ma-reinforce ang perception na pareho sa Rapide shop mo... if you do have a shop
    Mar 2013
    #205
    Correct recommendation is that the TS should find someone that will fix her car. Tingnan mo hangang ngayon di pa nagagawa dahil pinipilit nyong DIY eh.
    Para kang anak ng mekaniko ko dati. Pina silip ko lang source nang leak, butas ang block agad ang finding ni di pa nga nasilip ng maayos ang ilalim ng makina.
    Battery palang sabit ka na eh.
    cathy: "my car won't start"
    naputol timing belt mo
    it is a 1996 corolla, right? what is your odometer reading? what is your engine type? this year of corollas are run on timing belt. any difference in sound as you are cranking? any unusual noise while cranking?
    stuck up makina mo
    if you have 4AFE, your engine is non interference type-meaning-even if your timing belt broke while the crankshaft was turning, it will not have severe engine damage because the valves and the pistons do not share the same space. it might sound locked up if :
    1- the camshaft lost lubrications and has seized
    2-the injector/s is/are leaking making the piston hydrolock
    3-the crankshaft is seized.
    4-funny as it seems, maybe an alternator, idler pulley, water pump or other accessory might be seized restricting free movement of the crankshaft pulley.
    5-if it was a manual transaxle equipped car, the clutch or transaxle maybe locked up
    6-hopefully, not your pistons seized in the cylinder bore.
    #207
    Quote Originally Posted by ClaNker View Post
    Correct recommendation is that the TS should find someone that will fix her car. Tingnan mo hangang ngayon di pa nagagawa dahil pinipilit nyong DIY eh..
    I want to make my Dad and Kuya proud that I tried my best to solve it on my own first. I also like that I get to learn a lot when there is an issue with my car.
    Parang yung auto ko dati may nagsabi mekaniko na blow-by na daw engine, top overhaul naman yung isa Hindi naman.
    #208
    19.5K:thatsit:
    End of the year ko pa ibenta. Intay ko 2014 Corolla e
    Mar 2013
    #209
    I understand but you have to realize that your going to sell this car anyway. Get it fixed and get rid of it pronto, then thinker with your altis instead. Sadya mong sirain yan altis mo pag nabili mo ang bagong Corolla then punta ka kay uls pag naging "Destroy it yourself" and DIY adventures mo.
    Stick to the gameplan and that is sell that corolla. Have it fixed then get rid of it, don't wait till the end of this year.
    #210
    2 weeks na, may progress na ba?
    edit: top overhaul kaya in a day. hehe
    #211
    Ayan na ang progress ko
    Sent from my GT-N7100 using Tapatalk 4 Beta
    Oct 2011
    #212
    ano na progress cat?
    slo-mo kumilos si cathy
    #214
    teka, Di ba diagnose sa Oto stuck up? kunin ko na yan 30k, walang tinginan.
    hahaha
    cathy stuck up na makina niyan
    benta mo nalang as is
    Oct 2011
    #216
    pwede na mag asawa si cathy marunong na mag diagnose ng car mechanical problem.
    wala naman na-diagnose si cathy
    Mar 2013
    #218
    Saan Cath?
    tinanong ko din kay cathy yan
    sabi niya meron siya isang 2sm battery na ilan taon na di nagamit. dinala niya sa battery shop para ipa-check
    yan ang gagamitin niya sana pang start sa corolla
    kaya lang dead na daw sabi ng shop
    so yan ang progress niya
    hehe
    slo-mo
    #220
    kaya lang dead na sabi ng shop
    hehe
    :rofl:
    Yan nga ang progress ko
    1. Parallel - did not work
    2. Bring spare 2SM batt to Motolite - dead na daw
How to Know If It Is Only A Battery Problem
