Results 141 to 150 of 754
June 15th, 2013 04:21 PM #141
it is a 1996 corolla, right? what is your odometer reading? what is your engine type? this year of corollas are run on timing belt. any difference in sound as you are cranking? any unusual noise while cranking? i hate to say this but confirm first. don't rush into previous post guesses. like they said, it has become a science. better to be that way than guessing.
June 15th, 2013 04:27 PM #142
dont rush into previous post guesses pero dapat i-consider mo guess niya haha
ayaw lang mag start timing belt agad ang problema
June 15th, 2013 04:30 PM #144
crank wont start so it's logical to think fuel or ignition yan
hindi out of nowhere guessing yan
June 15th, 2013 04:30 PM #145
Yes. It's a 1996 Gli. The odometer reading is 184012 na pala I already had the timing belt replaced when it reached 100k, I did not notice any unusual noise. I only tried to start it thrice. I turned the key all the way na pero ayaw tumuloy yung pagikot (?)
What I want to find out is if this can still start from push start method? or there are less chances?
June 15th, 2013 04:32 PM #146
June 15th, 2013 04:33 PM #147
June 15th, 2013 04:33 PM #148
June 15th, 2013 04:47 PM #150
the triumph of man over... man!, using the crudest of implements (by modern standards).
Traffic!
