Results 81 to 90 of 754
June 5th, 2013 12:27 AM #81
*12vdc, thanks. I'll look up that jumper cable pero parang gusto ko yung ni recommend ni CVT na may instruction pa. Tingin ko kaya nagkaloko loko yung Lancer ko kasi palpak mga ginagawa ko. I can't afford to do that with my Corolla anymore.
Things I need to buy:
Jumper Cable - minimum 200A
Battery Monitor - Digital
BTW wala rin pala akong EWD sa car
CVT wag mo naman awayin si Retz
June 5th, 2013 12:40 AM #83
OMG (parang Cathy no?)
you need instructions to use a jumper cable?
red clamp to positive terminal
black clamp to negative terminal
on both ends
June 5th, 2013 12:43 AM #84
ibang klase talaga si cathy
she can make a thread about battery and alternator entertaining
- Nov 2009
- 3,484
June 5th, 2013 12:56 AM #85Ansakit makasalita
Parallax nalala kopa yan yung optical error dun sa analog meter..so yeah, mas accurate digital given na well-calibrated.. Kaya hindi recommended sa test equipments yung cheap brands. Pero prefer nung iba ang analog since mas Ok filtering nya sa high frequency AC (based from my experience).
Cath, kung cheap lang yung plugin-type na Voltmeter, go for it. Pang monitor mo atleast dapat 13.5-14.2V charging voltage/engine running.
Kung gusto mo long term, invest ka sa proper Multitester like Sanwa, Fluke VOM - Pag ginawa mo to baka makumbinsi na si uls na cowboy ka..:rofl01:
Eto pa additional suggestion for monitoring your car (pwede na sa altis-check compatibility chart)
June 5th, 2013 12:59 AM #86
haha
maconvince ako pag nag jeep si cathy papunta raon para bumili ng sanwa hehe
June 5th, 2013 01:04 AM #87
Dami kaya instructions Saan ko una ikakabit yung clamp sa dead o sa working battery? Yung red ba mauna o yung black. Kailangan ba pareho nakapatay pag kinabit ko. Baka mamaya magkamali ako masira ko pa yung car. Tingin ko nga kaya nasira lancer ko dahil sa mali pag kabit ko dati hehe
June 5th, 2013 01:08 AM #88
June 5th, 2013 01:09 AM #89
June 5th, 2013 01:13 AM #90
IIRC they're with AVID. The reported numbers in the TG article are from CAMPI.
Car Sales Data (2024)
