correct.
sports mode is like driving a manual less the clutch pedal. no need to release the accelerator if you want to switch between +/-.
correct.
Hi, what color and model of cruze did you prefer sir?![]()
About your questions. Its safe to shift/change your gear when it comes to shifting from 'D'rive to the +/- mode already whenever your moving or at full stop. But not in 'R'everse where you have to do a full stop to engage it.
When using the sport mode +/-, just take care of it like the manual tranny..
You can up-shift or down-shift it with or without your foot on the gas pedal. And the good thing is that, whenever you forget to up/down-shift your gear, it just gonna shift it self up/down to avoid stressing your engine..![]()
Just always check and take care of your A/T transmission by checking your engine oil and your ATF to avoid BIG problems.![]()
talaga? wierd...
ok, this is base on my santa fe (sold) which has the same type of transmission as of the CRUZE.
if you're using the manual mode or sports mode, the transmission wont shift to next higher gear unless done by the driver. however, the transmission will shift to next lower gear (automatic) if engine speed becomes low and could compensate the actual speed that the car is cruising...
Me nag-advice sa akin na expert sa Auto tranny, sa first service ng Tranny, make it * 35K km.
Yung kasunod na servicing, as usual na...
Ano sa palagay nyo?
Sa akin, sundin ko ang payo nya.....![]()
di mo ako nagets bro, suppose nasa 6kto 7k RPM ka na at ayaw mo pa magchange gear at delikado ka na sa redline, siya mismo ang magchange gear para sa iyo...yan ang isang safety feature ng sasakyan ngayon....
Ewan ko lang sa Cruze, sa Kia Forte ko ay ganyan....(sa panahon ngayon-halos parepareho na sila)
*Chadzxp2:
Don't worry so much on how the transmission will react on when to shift it up or down. Because Cruze has this Driving recognition where it will remember your driving pattern..Incase you want to be on economic driving or the aggressive part that is..
Iba na talaga ngayon bro, isipin ba natin na Korean sedans ay may start-stop button na usually sa Luxury cars lang meron????
Halimbawa noob ako sa manibela at naipasok ko sa Sports mode ang kambiyo, di ko alam kung paano kambiyuhin ang up and down basta naipasok ko siya sa Sports mode, bahala na si batman...
ano mangyayari kung walang safety features? sabog ang makina!!!!
e bakit pa imbentuhin ang Sportsmode kung di pala safe? sana purely automatic tranny lang siya gaya ng mga lumang modelo...
Walang masama sa palitan ng kurro kuro, para sa ating lahat ito mga sweet lovers.....![]()
Idagdag ko pa, kapag nasa sports mode ka at ang gear mo ay nasa higher(ika4 or 5 gears) at nasa rekta ka....120 or above.....at biglang kailangan mong magpreno at huminto, nothing to worry about shifting your gear pababa, kusa siyang bababa....kapag fully stop ka na, balik siya sa gear#1.....
good day mga cruzer, got my ls m/t last may, so far im so happy with my cruze, seeing people even mga naka FD na civic napapatingin. anyways have anyone experience the smell from the outside comes inside your cruze even naka closed na ang ventilation
using the TAPShift/sport mode of the cruze is just like pushing your gear to get more power by not fully stepping on the gas pedal.. For ex. when overtaking and engine brake, it avoids the red line by shifting your gear up or down automatically when engage in sport mode..![]()
