*bro cns
so rare i parked the car under the sun also but i remove the camera from it's mount if there's a call. i have this small thermo bag where i put the camera then i can safely leave the camera inside my console box.
safe na sya at least from the harsh oven like temps while the car is baking under the sun. also never i removed the power adapter from the lighter socket since day 1, no problem at all.
4 years for a no name dashcam? That's one sturdy cam you got there bro. Nice!
Will remove it na nga lang if ever i will be parking in the oven este open.
I never pulled the power adapter too, i turned off na lang the parking mode. Baka kasi pagbalik ko diskarga nabattery ko mahirap na.
Thanks bro!
Dash cams with parking mode doesn't get power from the car's battery. Kung properly wired naman, yung 12volt supply nya is turned off pag tanggal ng susi.
Parking mode of dashcam will get power from internal battery until maubos.
What's the edge of 520? Dual cam yan diba? Other cam facing inside the cabin?
Capture quality? Who's better?
Speed alarm, lane departure, front collision? You don't need a device for that.
Actually I turned that off already.
Oh no parking mode si 520? Among the features ni 220 yun medyo helpful lalo na pag nasa alanganin lugar ka nakapark.
Kaso every motion infront detected nirerecord niya, if busy yung lugar malamang ubos agad battery niya hehe
Guys mura ba o mahal ang dp200 = Php4950 at dp220 = Php5850.?
Sent from my SM-G920F using Tapatalk
Mura.
7.5k bili ko eh.
May warranty offered yan nakita mo?
The advantage of the 520 is it's a dual cam setup. So aside from recording yung harap/hood view, you can record the inside of the cabin. The second cam can swivel. I have the 520. I point the second camera to the driver side so I can record as well pag may traffic enforcer na loko loko.
Nakaka conscious lang minsan knowing that everything is recorded including the inside of the car. But it's a second security layer I'm willing to have.
***ingat lang sa mga gustong gumaya sa "fake taxi" baka malimutan mo it's recording ;) ***
according to the dp220 manual, parking mode will be triggered by motion;
you may check it here * 11:20
though hindi ko pa nasubukan mag-parking mode sa dp220 ko.
O apologies on that, I stand corrected. I thought motion infront of the cam will trigger it. I tried waving my hand in front of it while the engine is off, i thought it recorded. Baka naconfuse lang ako.
Thanks.
Around 30 minutes ubos na battery nyan sa parking mode kung nakaharap sa busy street.
Sent from my Asus ZenFone 2 using Tapatalk
* CNS & Remzam
Thanks, will go for 520.
Is it possible to mount our cam on the dash with the suction cup/adhesive provided?
Sent from my iPhone
*makyong, suction cups work in smooth surfaces where it can trap air. Dashboards are usually textured surfaces.
In my old garmin gps, it came with a flat metal plate with 3m tape on the other side. That's what I stick on my dashboard and then use the suction cup over that plate.
