Previously, they offered as much as 20% discount for all variants but now it is down to 15%. You could further lower the price using the 80 peso voucher.
Sent from my MI 5 using Tapatalk
Ano maganda dashcam na di masyado masakit sa bulsa na pwede ihardwire? Ayaw ko kasi ng madaming nakasabit.
You can backread for recommendations.
But if you want to be spoonfed, I highly recommend the Mini 0805 for 3.5k. If you need a dual-camera setup, then I recommend the Mini 0906 for 5.5k.
Any dashcam can be hardwired as long as you have a hardwire kit. You don't need to hardwire though if you want a clean look. This is how my Mini 0805 looks like on my Civic:
No wires except that blue USB extension cord. It can be made more discreet by using a black cord although as it is, you can't see the cord anymore since it's by the passenger footwell.
Here's how the Mini 0906 looks like on our CR-V - again, no exposed wires (even the rear cam):
DIY. It's a very straightforward installation - just tuck the wires inside the headliner, route it through the A-pillar and behind the glovebox, then bring it out to the 12V socket. I use a 3-port USB charger so that I can still charge my phones with the other 2 slots while 1 slot is dedicated to the dashcam.
*****fixed the st**id link.
https://image.ibb.co/hgkBHc/IMG_20180221_182406.jpg
Got the Viofo A119 v2. Was considering the Mini series but read about reliability issues online (I think that older versions are good based on reviews but didn't want to risk).
Box was a bit damaged, but thankfully camera works.
Still waiting for my microSD card before I install in my car. Was planning to hardwire, but decided I didn't want to mess around with the car's electrical just yet. Also, Jut's post demonstrated that a clean install is possible using the 12volt socket.
Damn! Mahal ng ddpai mini3. Thought close sa price ng mini2. lol
Does anyone has a guide for hardwiring the mini2 using their hardwire kit? I’m a noob basically about wiring and i’m here somewhere where electrician is not available... so i have to diy... pls help... thanks!
try this
Dashcam Installation Instructions | Dash Cam Hardwire How-To Guide
take note of the position of the fusetap. the current should flow across the fuse before going to the power adaptor
Piggy-back fuseholders - a right way and a wrong way? | DashCamTalk
If you dont have a fuse tap you can google some ways to tap into the fuse box.
Something is terribly wrong with my mini 0906 - night video quality is so much worse than my 0805 when they should have the same quality as they should have the same internals.
0805:
0906:
Both dashcams have the same settings (1080p 30 fps), both have the same tint (3M CS20).
Can other folks with mini 0906 dashcams post screenshots of their nighttime videos as well?
My bad, the 0906 and 0805 apparently have different chipsets. The 0906 uses the Novatek NT96663 while the 0805 uses the Ambarella A7.
Still, the 0906 has far better video quality from the reviews on YouTube than the unit I have. I've already tried resetting it and upgrading my firmware, same crappy quality.
This is how it should look:
