Eto nakakatawa lang, tinanong ko si ate kung kamusta naman daw si kuya. [emoji23][emoji23]
Ayun nakapark din naman ako [emoji28]
Kamusta daw si kuya? - YouTube
Sent from my SM-C900F using Tapatalk
hi mga sirDDPai mini3 is still available po. 5 megapixels 1600p HD with built in 32gb storage, rotatable and detachable camera.
kindly visit our page * Bry'z Gizmos - Electronics - Las Pinas | Facebook - 81 Reviews - 815 Photos po for more info. thanks!
any recommended dashcam for the rear? i am using a xiaomi yi on the front and it is just right for my needs.
1. good nightvision (because i have tints on the rear windshield) #1 priority
2. small (prefer ko wala na display)
3. relatively cheap
4. no need for extra features like wifi, gps, etc basta meron yung basics.
iniisip ko na rin to stick another xiaomi yi on the back pero parang sobra na. i tried using my old sj4000 in the rear but nightvision was not so good.
*ninjababez nakakuha na kayo nung xiaomi 70 minutes? parang pwede tutal naka-xiaomi yi na ako sa harap.
*jut so for so good naman mini 0906 nyo? wala naman nagiging problema?
thanks!
yun ddpai mini kinuha ko bro, OK sana kaso pag VLT 20 yun tint mo madilim talaga. im thinking VLT40 and up is OK for night captures. baka kumuha din ako xiaomi 70, then compare ko sa ddpai mini ko. kung sino mas OK, yun ang iiwan ko sa windshield, then sa likod yung isa![]()
kagabi i put the xiaomi yi (3m cs05/darkest) on the back tapos sj4000 infront (3m cs35/lightest). mas maliwanag at mas clear pa yung xiaomi yi kesa sa sj4000 (expected since the sj4000 is old hardware). you might not be able to get plate numbers sa cars pag medyo malayo pa at minsan nag-glare yung headlights pero you can still see what is going on behind the car even on dark roads (bgc c5 going to slex, uturn then going back to bgc).
if the xiaomi 70 minutes can equal it, then yun na lang kukunin ko for the back. may idea ka saan makakakuha locally nung xiaomi 70? ebay ph lang kasi nakikita ko.
Hi guys!
Anybody using same dashcam as mine? Nagkaka problem ako connecting it on my phone. Also, getting some inputs if hardwired, or lighter ang powersource. Thanks and more power!
i thought the model number designates the VLT (ex CS35 = 35%, CS20 = 20%, CS05 = 5%) but correct me if i'm wrong. so i am using cs05 kaya 5%?
just got the xiaomi 70 minutes today. it is a little bigger than i imagined it to be. nakabit ko na sa rear. very straightforward. just had to install an app sa phone kasi dun mo lang mapapalitan mga settings and makikita (via wifi live view) kung tama pagkaka-align. will be testing it out after dark kung fit sa needs ko.
