Results 31 to 40 of 231
January 21st, 2010 01:02 PM #31
- Mar 2007
- 239
January 21st, 2010 02:37 PM #32ok na ok ang thread na eto! thank you very much po sir NighthawkGT for taking the time to answer our questions
1 tanong na lang po: ilan watts po ok sa montero?
BANNER BANNER BANNER
- Jun 2008
- 1,439
January 21st, 2010 04:44 PM #33
January 21st, 2010 07:19 PM #35
if you have a bixenon projector, its okay. the bulb stays fixed, the only thing that is moving is the cut off shield. this cut off shield retracts down, to give way for additional lighting above cut off. you can cycle this on and off, the only thing that can go wrong is frying the solenoid of your projectors hahaha!
just as long as the bulb is not switched on and off your bulb and ballast will do just fine
January 21st, 2010 07:31 PM #36
okay this has been debated for quite so long in other forums. HID was designed to run at 35W. that is one of its advantages, lower power consumption and high lumen rating.
of course there are some people, including me, that cant get enough of bright, intense, CONTROLLED lighting. running 50W ballast will result in a much more higher bulb temperatures. As tested by others, running a 35W china bulb with 50W ballast produce so much heat that it can damage the chrome in the reflector bowl of projectors, much as with semi sealed projectors.
so running 50W ballast with china bulbs has risks of damaging the projector. What other people do is they use OEM philips bulbs. that produce much lower temperatures than running with china bulbs but ofcourse much higher than running standard 35W bulb.
as far as boosting ballasts power is concerned, some mercedes benzes have a smart ballast in which it boost the ballast output power to 38W when traveling at high speeds, this increases visibility about 100m as i have read somewhere. its a very conservative increase and would not damage the projectors
January 21st, 2010 09:36 PM #37
January 21st, 2010 10:03 PM #38
o, nighthawk, thanks for sharing them what you taught me nung nagpa-retrofit ako sa yo a few months ago. i'm glad na maganda ang respond ng mga tsikoteers sa thread mo.
January 21st, 2010 10:33 PM #39
^^ Oo nga pala. thanks NH. looking forward to meet you personally.
Btw, do you sell HID kits alone?
Pa PM price if ever. Thanks.
- Mar 2007
- 239
January 22nd, 2010 12:14 AM #40
Megawatt charging: https://www.youtube.com/watch?v=usUxO7y4z_E
BYD Philippines
