Page 4 of 12 FirstFirst 12345678 ... LastLast
Results 61 to 80 of 231
    Jul 2006
    #61
    Bakit sabi sa akin, kapag low beam HID lang pinalagay ko sa montero sport, kapag nag high beam ako, di ko na raw mapapansin na naka high beam kasi masasapawan daw ng HID low beam yung halogen high beam
    Jul 2006
    #62
    Why is it some of my friends told me that my halogen high beam will not be that bright if I installed HID on my projector low beams on the Montero Sport. Masasapawan daw ng low beam HID yung halogen high beam
    #63
    I think not completely masasapawan naman po siguro. Pwera na lang kung talagang malayo naaabot nung HID. Pero I think mas malayo pa rin pag high beam kahit halogen.
  4. #64
    if your low beam is not aimed right, or if its aimed too high, of course the output of the high beam will be overlapping the output of the low beam.
    this mostly happen on the dual reflector low beam and high beam in which the low beam has hid on its halogen reflector which acts like a high beam due to uncontrollable glare. so masasapawan talaga yung high beam na halogen pag ganun.
    but on the case of the montero i think it wont happen
    #65
    I had Nighthawk done my HID with a Retrofit Projector last week. He did a great job. Looks OEM. I am very happy with it. =)
    Parts used:
    - a clear lensed FXR bixenon projectors with color modification
    - philips 85122+ d2s 4300k color bulbs
    - apollo shrouds
    The light is bright and yellowish in color. The output is wide - good for 3 to 4 lanes - with a sharp blue outline. No glare at all to incoming traffic. Yay!
    Before that, I was using a 6000k hid that was just installed directly into my lamp. While it was bright white, the light output was going everywhere and not directed. I hated that the bright white light does not mix well with the usual yellowish light of the other cars - it was distracting to me and the other drivers. I had to angle it low to avoid glare to incoming drivers causing the throw of the light to be so short that I couldn't dive safely on the highway. During the rainy months, the white light was reflecting off the rain drops that I can't see the road much. I was actually contemplating to change back to the oem Jazz lamp until I saw nighthawk's post retrofit projector. I am now a happy camper.
    Aug 2009
    #66
    Sir san po shop niyo? gusto ko kasi mag pa HID sa Innova ko, eh from the pictures that were currently posted mukhang pulido kayong gumawa...
    #67
    yes pulido talaga gumawa yan si nighthawk. pero hindi simple ang process nito at hindi rin simple ang price nito.
    walang shop si nighthawk, AFAIK sa bahay lang siya gumagawa.
    nighthawk, gary quoted me 29k all in for Tucson. FX-R Lens, Philips bulbs, denso ballast, gatling shroud. magkano sayo?
    Aug 2005
    #68
    Sir NGT,kaya ba sa xtrail ko? naggagawa ba kayo ng home service?
  9. #69
    *starter12
    you have pm.
    *starex_gold
    you have pm.
    *monsrick
    you have pm.
    #70
    Sir NighthawkGT, how much the damage if im going to retrofit my ge??thanks..
  11. #71
    Quote Originally Posted by shotudown View Post
    PM sent bro. thanks
    Jan 2009
    #72
    Quote Originally Posted by font View Post
    Parts used:
    - apollo shrouds
    sir font mga gaano katagal ginawa yan? hi/lo ba sya? ginamit mo ba yung original headlights mo? magkano ang damage nyan? thanks.
    #73
    beefydog, pm sent
    Oct 2008
    #74
    Sir Knighthawk, magkano po damage kung ipapa ayos ko headlight Toyota Hiace Subic ko. bale HID Light na sana siguro mas ok dun ang quadprojector kasi Tarlac-Batangas lagi ang biyahe ko. PM niyo na lang ako, complete adress and contact number din.. Thanks!
  15. #75
    Quote Originally Posted by robel_76 View Post
    can you post pictures of the actual headlight? is it clear lens or fluted lens?
    by the way check your pm ren. thanks
    Oct 2009
    #76
    Nighthawk, what do you recommend for my 2008 honda crv? how much? thanks!
  17. #77
    Quote Originally Posted by samsantiago View Post
    your 2008 CRV is projector already. kahit halogen projector yan, a nice decent hid 4300k would be enough
    #78
    Hi,
    I have 07 isuzu alterra naka 8000 kelvin both low beam (projector) and fog lamps. ung projector ok ang cut offs, pero ung foglamps, like sinasabi above, scattered, uneven ung light (which don't look so bright at all).
    question po, is there a way to retrofit the foglamps for my alterra? where po pwede? my location is Cebu City. hehe
    Kaya pala pag may katabi akong car na naka HID rin, mas bright tingnan ang sa kanila kc concentrated ung light sa gitna, sa akin kc scattered. thanks sa mag reply!
    #79
    Quote Originally Posted by kwoshunli View Post
    Hi,
    sa alterra, it may be possible pero gagawa ng bagong foglights, say a DIY foglights using projectors. IMO, wag ka mag 8000k on fogs. better yet eh mag 4300k ka or 3000k kasi fog lights are designed to scatter light para makakita ka through foggy roads. also, i advise na mag 4300k ka on projectors mo. 1 pang reason yan kung bakit hindi maganda ang vision mo sa gabi at para na rin iwas bulag sa makakasalubong mo
    #80
    thanks po sa reply sir, hehe unfortunately d pwede ilipat ang foglights ko papunta sa headlights kc d sila parehas e. sayang kc pag palitan ko foglights kc bibili naman ako bago, then headlyt ko sira bibili rin, parang bili ako 2 pairs na, sayang talaga
Things to know when upgrading to HID
