Page 8 of 12 FirstFirst ... 456789101112 LastLast
Results 141 to 160 of 231
    #141
    Hello everyone. I am new here and was just looking through google about HID's on reflector housings when I came about this forum.
    I own a 2000 Mitsubishi Montero Sport and i just recently put bixenon 6500k's. And I must say its a nice improvement from my yellow halogen bulbs. Its has an OK cut off line. a small glare on the top of the cut of line, but not bad. I was wondering is this glare bad for other drivers? I have not been able to take some pictures but I will soon. I had to adjust my angle because before they were high, now their nice and low.
    However, I want to retrofit but I dont want to ruin my housing. I've been trying to look for some that already have been retrofitted but I couldnt find any. Do you know someone who can do it?
    I also have a problem with my 9007 bixenon not working. When I switch on my high nothing happens. And my high light indicator always stays on. I have tried switchin cables but it only works when i flick my high beam switch on again. I have yet to figure out whats wrong. Any help would be appreciated.
    Thank you.
  2. #142
    Quote Originally Posted by djabi90 View Post
    Thank you.
    for retrofitting jobs better leave it to the pros. less hassles. you got PM bro.
    with regards to the bixenon not working, it can be the bulbs solenoid thats busted or just wiring issues.
    #143
    you think maybe the computer think it has a blown bulb since the xenon use 35w and halogen uses 55w?
    i tried puttin in my original halogens and having one of them unplugged and my high beam light stays on.
  4. #144
    nope it will not cause that. whether your bulb is 35w or 55w there should be no issues, unless you run at higher wattage in which can burn the wires or bust the fuse.
    it appears there is a problem with your electrical wiring if thats the case.
    #145
    sir nighthawkGT, can you do retrofit for isuzu crosswind xto?
    #146
    Sir NighthawkGT, san po pwede mag pa retrofit ng 96 galant? Saka po if ever how much? Thanks.
    #147
    NH,
    pa PM naman for trooper including fogs! Thanks.
    #148
    Hello sir Nighthawk. Question po. Are the projector headlights being sold for the Altis in Sulit.com any good. The seller said it's from Taiwan.
    Thanks in advance po.
  9. #149
    double post :D
  10. #150
    Quote Originally Posted by <smash> View Post
    first you have to check the bulb type the projector uses. if its anything that uses halogen, then im gonna assume that the output is crap.
    if it uses anything that resembles a hid bulb like the D series bulb, then its a good buy.
    nevertheless the only way to find out is to test the light output in person.
    *s_quilicot, dretch and dcir
    kindly direct all inquiries and send an email to the address below:
    tim*nighthawkperformancelighting.com
    lets keep this thread as informative as much as possible and not a means to sell retrofits.
    #151
    Thanks for the quick reply sir. I'll keep you posted on the item.
    Feb 2010
    #152
    ...pwede b ipa retrofit ang hl ng spacewagon? "94
  13. #153
    sir basta clear headlamp assembly pwedeng i retrofit
    #154
    sir nighthawk i need your help.. may H1 8000k bulb na po ako.. regalo lang.. btw honda city idsi '03 model po yung akin.. ang prob ko lang po kasi is wala akong mahanap na projector lang ang ibebenta sa akin.. laging may kasamang bulb.. eh sayang din naman yung bulb ko kung ganun.. hmm.. any suggestions po ba? TIA ^^
  15. #155
    Quote Originally Posted by Paul_01 View Post
    bro we can do something about that. kindly check your pm. thanks
    #156
    that was a quick reply.. hehe.. pm replied sir.. thanks..
    Aug 2008
    #157
    sir, i'm planning to upgrade from my halogens to HIDs.. my ride's a Honda Jazz 2009.. nagdadalawang isip akong bumili kasi baka nga sabog yung buga at makasilaw ako sa ibang drivers.. what would you suggest po na low-cost solution? pa-PM na rin po ng estimate price... thanks!
    #158
    Quote Originally Posted by chuckie_bhoi View Post
    Bolt-on projectors.
  19. #159
    gaanong ka low cost ba ito? you got PM bro
    May 2008
    #160
    Do 55w HID kits produce the same heat in comparison to stock halogen 55/60w bulbs? I'm a bit concerned if my clear lens would darken / have discoloration if I switch to HID.
Things to know when upgrading to HID
