Page 63 of 70 FirstFirst ... 1353596061626364656667 ... LastLast
Results 1,241 to 1,260 of 1387
    Jun 2016
    #1241
    Quote Originally Posted by zechs View Post
    So pag naka-on low beam mo, ung hella naka-open din right?
    Hindi ba kaya i-retrofit ung low beams?
    Pag open ang low beam, the hella projectors also open. The low beam can still be retrofitted. Just don’t know how much more bright it could produce by changing it from stock projectors with led bulbs.
    Oct 2003
    #1242
    Ah I see. Thats why I asked if kaya i-rewire na lang na ung stock projectors mo, to make it high beam only.
    Magsasapawan lang ung output ng mga projectors mo if retrofitted both. Unless you adjust it in a way na spread out ung hotspots nila so lalawak ung beam pattern mo.
    Jun 2016
    #1243
    Thanks a lot for the VG advice!!!
    Jan 2008
    #1244
    Tsaka parang mas mabilis masira un polycarbonate lens ng HL pag quad setup, pag madalas gamitin
    Sent from my Redmi Note 8 Pro using Tapatalk
    Jun 2016
    #1245
    Quote Originally Posted by kkreuk18 View Post
    I’ll just stick to my current setup - retrofitted on high beams using d2s bi beam projectors with branded bulbs and ballasts, and stock projectors on low beams with cree xhp70 led bulbs.
    Oct 2019
    #1246
    Quote Originally Posted by ealdree View Post
    anong car na nilagay retrofitted projector on high beams?
    Jun 2016
    #1247
    Quote Originally Posted by mb1 View Post
    Fortuner 2016(od face). My friend told me that an installer may add vent membranes at the back of the lamp where the heat from hid bulbs will pass through.
    Thinking of retrofitting the low beams again. LOL!!!!!
    Oct 2003
    #1248
    This is neverending. Haha. Im Considering upgrading. Hit me up if you're intrerested with hella g5r projectors.
    Oct 2019
    #1249
    Sagad mo na po. Retrofit mo na. Hehe
    Is G5R better than G5-EX?
    Oct 2003
    #1250
    Only difference I believe is the AR coating
    Dec 2013
    #1251
    G5-R hotspot malakas, G5-EX widespread beam pattern, G5-EXL pinakamalakas focus ng hotspot. Napanood ko lang sa youtube ni lightwerks. Natutuwa ako manood ng mga diy retrofit. Nag diy fog retrofit lang ako.
    Jun 2016
    #1252
    Quote Originally Posted by Geronimo Valino View Post
    I have g5 ex on my hi beams. What would be the best projectors for my low beams - G5-R, G5-EX or G5-EXL?
    Oct 2003
    #1253
    Kung tama sinabi ni sir geronimo then get the g5-exl. Pero i would interchange the two since sabi ni sir geronimo, widespread beam pattern ng g5-ex. G5-exl for high beams since focused hotspot.
    Jun 2016
    #1254
    Thanks a lot!!!
    Dec 2013
    #1255
    G5-R G5-EX G5-EXL Projector Comparison + Lux Testing - YouTube
    Post ko na lang din link dito. Kala mo yung simpleng upgrade ng hid masatisfied ka na dahil sa malaking improvement ng headlight output from halogen at led tapos meron pa pala levels ng hid upgrade. Depende pa sa projector lens, ballast at hid bulb.
    Sa may fog hid separate switch yung fog high beam nyo o kasabay ng stock high beam?
    Oct 2019
    #1256
    I see. Thank you po.
    Oct 2019
    #1257
    Thank you. So if you are after for hotspot over widespread then choose either G5R or G5-EXL pala. Ang G5-EXL is 3.2 inch so not all cars can fit this projector ata.
    Oct 2019
    #1258
    Maganda sana po if ung G5-EXL ang inner projector nyo then G5-EX ang outer projector pero depende pa rin if mag-fit sa Forty nyo.
    Though nakakita na ako na ang set up sa current Everest.. G5-EXL ang outer projector then G5-EX ang inner projector, maganda naman ang bato ng ilaw. Ninlagay ang G5-EXL sa outer part ng Everest kasi un lang ung way para ma-fit sa HL housing.
    Oct 2003
    #1259
    Since I've replaced my Osram CBI D2S bulbs to Osram CBBs, I have no need for the old bulbs. PM me if anyone of you here is interested. Hehe
    Jun 2016
    #1260
    hi Sir! anong series ng Sunbloc tint ung may VLT of 26% and saan nyo balak papalit ng tint? tsaka malaki ba ang jump ng difference from VLT 20% to 26% with your current bulb na gamit nyo (CBB) sa retrofitted headlight nyo? thank you!
    How does BF Film compare to Solrex and Sunbloc? I have 3m medium tint on WS and dark tint on the sides and planning to change. I have difficulty of viewing cars on the side at night.
Planning on getting an HID retrofit
