Results 221 to 230 of 1387
- Oct 2009
- 152
August 30th, 2017 07:56 PM #221*hypnos- HIDretrofit doesn't mention brands, or maybe I didn't ask correctly. Even for their HID retrofits I couldn't find out beforehand what ballasts would be used. For Redline, they told me its a clone of Koito bi beams. I was also told that they could source a Koito but its going to be expensive at more than 40k. On the Morimotos, i think these should be much more tested than the clones but its still risky in the long run for me. Morimoto- I don't think they are capable of conducting the same amount of testing as the big brands like hella, stanley, konti, who manufacture their own.
If I had a source of original 2.0v headlights for my 1.6 altis at a price not too far from getting HID retrofits, I would have gone this route even if the single beam LED projectors were not as defined, bluer in color, and not as powerful as the stage 3 retrofits since these would probably be more reliable.
- Oct 2009
- 152
August 30th, 2017 08:10 PM #222
August 30th, 2017 09:33 PM #223
I know its expensive. Even the MH1 has better output. The reason I brought it up its because by far as of the moment those are the only led+projector combo IMO that can perform good in light throw, width, beam patern and less streaking. I also pointed out that since it is new there is not much of a feedback for it yet also one of my concerns about these is that it has cooling fans hence that is another thing to worry about. Will the cooling fan be able to work near the led bulbs life span? Dahil pag na unang tumirik ang fan then bubuksan mo na naman yung headlight mo.[/quote]
I'm smiling when I see someone make an account just to reply a thread
FIY I'm just spreading the proper use of headlight dahil marami pa rin mga motorista sa daan ngayun na mapapamura ka sa silaw ng mga headlight nila dahil either walang mga alam or just an ass and walang pake sa ibang motorista.
You said you are about facts. Try to visit this one too Informative Articles - HiDplanet : The Official Automotive Lighting Forum
When I compare that led vs hid pics it is apples to apples. You see the pics that they post is how their led product is better than a HID. so I post a pics with their comparison plus a properly retrofitted HID. If you look closely on their comparison they did not use a proper hid+projector combo. So how is that fair? Also sa comparison nila may road shot ang led tapos ang hid wala? When you make a wall shot it and claim na mas malakas ang product mo kesa sa iba put a lux meter and indicate the distance.
The guy said that the led was better and mas malakas kaysa magpa retrofit ka so I ask him to prove it. Also I said when you claim na mas malakas ang product mo kaysa sa isang product you have to be able to back it up. Daming factors lalo na sa hid retrofitting. Bulb, lens, projector, shield, ballast are just some of them. And how can you say that your product is better or malakas when you dont even have a proper cut-off and step? Also I question the process of swapping the bulb just because it fits? Hence the optics theory.
I never said brightness is about sharpness. Also Lux, lumens and candela are different from each other.
I see it all over the road today, cars and trucks with lights that could be seen from space on a clear night. These days it seems like everyone has a set of super bright headlights,both on either Led or best quality Retrofit, both have disadvantages and advantages, but is brighter or good cutoff always better?
I say no. When auto lighting claims to be the brightest or better cutoff on the market, it doesn’t necessarily mean you are getting a better product. This is just like audio manufacturer claims of high wattage, without mention of the RMS rating, or usable power. There is another important factor to consider other than just lumen output or bulb temperature its called candella or intensity of light. Again like i said both are good when in fact im using Hid now for four years, driving just 1 hour a night since my work is like just a stone throw away from my house, traffic makes it longer. i may have to try Led this time to see the difference.
This is what i got from the internet this is old and Im sure both platforms have evolve.
Access Denied
Xenon headlights
Xenon lights, also known as high-intensity discharge (HID) lights, produce a brighter light than halogen bulbs and with far less heat. The blue-white light emitted by xenon bulbs is so bright, it has been known to "blind" other drivers.
These headlights require a large amount of power at the outset to produce their first burst of light, but once fully operational, they require much less energy to maintain constant brightness.
Xenon bulbs have a long lifespan and emit little heat, but they cost more than halogen bulbs.
LED headlights
LEDs are the most recent innovation in headlight technology. Instead of gas and filaments, LEDs rely on small diodes that produce light when electric current excites their electrons. They need an low amount of power to work but do produce a significant amount of heat on the diode. This requires heat control systems at the bottom of the headlight and near other car components. If this system fails, not just the light, but other electronics could be affected.
The small size of LEDs means they can be formed into almost any shape, and their light is naturally directional rather than diffuse, making them an excellent choice for headlights.
Technology changes so its really upto the endusers choice which is best for them in extreme condition specially at night, whatever works for them practical and value for money.
Cheers
Just lurkingLast edited by D3nb3r; August 30th, 2017 at 09:59 PM.
August 31st, 2017 12:04 AM #224
I forgot to emphasize this one. This test will not prove anything and will only contradict to what i've been saying all along. You cant just use one led bulb from a projector and transfer it into a projector that is designed for an HID. The optics will not be the same. Even a very very small mis-alignment sa bulb seat ang effect nyan will be magnified when the light passes the lens. another problem pano ma secure yung bulb from a led projector duns a bulb seat na design for HID projector like for example the d2s. Kahit na yung butas pa lang di na siguro ma pasok ang led bulbs at kung mapasok man gaano kalayo/lapit ang led bulb sa cut-off shield or sa reflector? Example is the Mled, bi-led of morimoto or the bi-leds made by profile. Do you see them swaping leds and hid on the same projectors? kahit yung bi-led na gawa ng profile na almost similar to MH1 pero sa physical and mounting dimensions lang similar at magka iba parin ang bulb seat. Kung pwede pala yan eh di bibili na lang ako ng pina ka malakas na led tapos salpak ko sa mga projectors like rx350, acura TL or s2000. And if that suggestion of yours is correct then TRS, lightwerkz or blackflame cutoms, redline, garry quizon etc., should offer that process on their retrofit.
Even lens swapping ay hindi basta basta though marami gumagawa nito. sometimes need mo spacers to tune the lens. One example is hindi mo pwede gamitin ang STi-R lens sa projector na design for sa ZKW-R or vise versa kahit same 3" pa sila. Pwede ka lang gumamit ng replacement lens kung pareho ang depth ng old at replacement lens mo.
Just because you can doesnt mean you should.Last edited by D3nb3r; August 31st, 2017 at 01:30 AM.
- Dec 2014
- 165
August 31st, 2017 08:12 AM #225
August 31st, 2017 09:42 AM #226
yeah you're right. optima is a contender on led projectors lalo na if basehan ang price. Also when I said na MH1 has better output. I might have over reacted
I should have said its subjective. What the bi-leds might be lacking in width they sure make up for the hot spots against MH1.
August 31st, 2017 10:29 AM #227
Pampalamig muna. Already planning to have mine retrofitted pero bumigay na low beam ko kagabi and today coding ako, babyahe pa naman sana ako bukas madaling araw sa probinsiya. Halogen (readily available sa banawe) or tiis para maka retrofit. Bwe**t!
Sent from my SM-G930F using Tapatalk
- Oct 2009
- 152
August 31st, 2017 11:49 AM #229Just to chime in, its not about LED vs HID vs Halogen technology but getting better but safe and responsible head lights. A lot of engineering went into designing the headlight assemblies so personally, I find it hard to trust LED bulb swaps in halogen reflector headlights. Look at the current civic and top spec altis, these use specific optics designed for the LED headlight assembly. If all it took was a simple LED bulb swap I think we would see most brands use these rather than spend the time and money to develop their own LED assemblies.
Replaced with the Pilot Sport 5 na ata, but the available sizes aren't yet as broad as the PS4.
Finding the Best Tire for You
