Page 26 of 70 FirstFirst ... 1622232425262728293036 ... LastLast
Results 501 to 520 of 1387
    Mar 2012
    #501
    Quote Originally Posted by Sleepcare View Post
    Dinemo niya yung actual lens itself. Nilinisan muna niya from the boxes yung 2 sample lenses then pinahawak saakin yung lenses then sabi niya tumingin ako sa malayo thru the lenses, yung Class B na sinasabi niya totoo ngang malabo yung view as compared doon sa isa pang dinemo saakin na Class A. (Think of it as the glass na nabibili sa department store vs yung glasses na ginagamit sa carinderia for the service water.)
    Nakakainis lang kasi nakalimutan ko na kung anong shop yung nagdemo saakin.
    Ah ganun po ba. Sa projector lens kasi meron tinatawag na fresnel at clear lenses and sa pagkaka alam ko meron fresnel lens ang kioto q5. Mas intense output and sharp cut-off ang clear lens if compare sa fresnel. And if pinagtabi mo ang dalawang lens na yan malabo tignan ang fresnel.
    Aug 2009
    #502
    Quote Originally Posted by D3nb3r View Post
    Fresnel pala yung term doon. Pero iba parin talaga yung quality boss for me nung kay Xenon.
    Siguro nga yung sharp cut-off yung hinahanap ko na hindi ko makita sakanya.
    For the record, hindi ko sinisiraan si Xenon ah. Ok sa ok naman talaga siya gumawa especially for budget builds but siguro nga lang hindi lang umabot sa expected output ko yung work.
    Oct 2003
    #503
    It all depends sa budget, right? Siguro nga if you can spend up to 30K for a retrofit, then go. And you really should expect the best of the best when it comes to output and cutoff.
    So far ako, satisfied naman ako sa sharpness ng cutoff ni xenon concepts. If I wanted something more then I should be willing to spend more which I am not haha as long as properly installed, aligned and output and cut off is good. Im okay with it.
    And between the koito q5 projectors, ibat ibang china companies produces these q5 projectors. NHK is just one company who makes them. Ang hindi ko alam if NHK makes class A or class B na q5 projectors. Hehe
    Dec 2014
    #504
    Sir i would like to be enlightened. You mean to say for NHK for example, there is a class A q5 and a class B q5? Isnt NHK in itself considered class A already?
    Oct 2009
    #505
    If you back read a bit someone who tried Xenon Concepts mentioned that they used NHK ballasts and bulbs, while someone else posted that they got some lesser known ballasts and bulbs which were available at Lazada. Just guessing, but Xenon Concepts may be sourcing different brands of bulbs and ballasts. The bulb and ballast differences may be the reason why some have seen lower output from Xenon Concepts. If you look at the measurements posted some pages back, there is a big difference int he output among the bulb brands.
    Oct 2003
    #506
    *hypnos,
    What I meant was hindi natin alam if NHK (company itself) is selling class A and class B na Q5 projectors.
    We are not sure kung bakit na kung same NHK Q5 projectors, same NHK ballast, and same NHK bulbs, bakit magkaiba output. Kasi sa akin, ung sa dalawang car na na-install ng stage 2 ni xenon concepts, napansin ko na ung sa isang car ko, iba ung ballast and igniter nya. Could be na latest edition ni NHK yun kaya magkaiba. Napansin ko lang na mas mabilis ung warm up time nung latest edition na ballast nya. Projector wise, its the same daw and same bulbs.
    Siguro ang kailangan natin gawin is get the NHK projector-ballast-bulb from one retrofitter and pit it against the other retrofitter's NHK projector-ballast-bulb. Para malaman natin why the other warrants a higher pricepoint than the other. Hehe
    Aug 2009
    #507
    When I brought up the Class A and Class B lenses ng Koito Q5, let's say NHK is making Class A Koito Q5. Then may other sub-con na gumagawa din ng copy ni NHK Koito Q5 which made it Class B pero labelled as NHK Koito Q5 parin. I think yun yung point ng pinuntahan kong retrofitter noon.
    Kung maalala ko yung retrofitter na yun, i'll visit him then post here some details. Hopefully maalala ko.. ang dami ko din kasi napuntahang retrofitters noon for quality checking ng trabaho.
    Dec 2014
    #508
    Quote Originally Posted by zechs View Post
    *hypnos,
    that's good if the installer is also updating their product. i thought that same NHK Q5 projectors with the same everything else gives different output. I am of course assuming that NHK also does some QA on its products as opposed to the generic projectors on aliexpress
    Oct 2003
    #509
    *sleepcare,
    Probably ganun nga. We are not sure if lahat ng retrofitters dito get the NHK brand (projectors, ballast and bulb) from one china supplier only. Malamang marami sila. So possibly, iba iba nga ang output nila. Hehe
    I think natanong ko dati kay xenon concepts kung ung q5 projectors nya is the latest one (which is based sa morimoto d2s 4.0), sabi naman nya yes it is.
    Mar 2012
    #510
    May tinanong ako dati installer and ask him magkano singil nya sa retrofit nya including philips xv and sabi ko if may fxr siya. Sabi sa akin luma na daw ang fxr and q5 na ang in ngayun and natawa na lang ako hahaha. Fxr projectors is a legend na sa mga oem spec projectors I mean q5 is not bad provided above average ang ballast and bulb mo but to tell me na as if wala na sa scene ang fxr is funny
    My point is alamin natin if knowledgeable ba talaga ang installer natin or even tayo din dapat mag research din. It pays to know kung anong kinakabit sa sasakyan natin kaya ok din na dinidiscuss yung mga projectors dito like if may class A or B ba ang q5.
    Update lang, lens etching will be available na sa firedrake soon. Curious ako sa finish product nila if pulido ba and sa output.
    Oct 2003
    #511
    Ang tagal dumating ng G5 ko....
    Mar 2012
    #512
    kala ko local mo lang binili sir. Galing lightwerkz ba?
    Oct 2003
    #513
    Inorder ko kay xenon concepts. Di ako umabot doon sa isang batch nya eh. Next week tentative arrival. Hopefully im not going to be disappointed.
    Aug 2011
    #514
    No problem naman on the width, just the concentration of the lighting on the road, malakas yung sa malapit compared dun sa malayo. Not a big deal really, maganda pa rin naman lighting niya in real-world use.
    Setup for the HID: Q5 projectors, NHK bulbs and ballasts. Bagong palit yung NHK bulbs, bagong linis yung projector housing.
    sir jut, saan ka nagpa retrofit? sorry hindi na ako nag back thread. wala ba moist ng water pag umulan or car wash? lastly, durable ba ung ballast and bulb. TIA
    #515
    Quote Originally Posted by Tj_abs View Post
    Redline Autoworks. No moist, ballast and bulb are still fine after 2 years of use.
    Aug 2011
    #516
    thanks sir jut for inputs. ang stage 2 ni sir tots ngyon is 19k pero ang ballast na gamit hylux ata at ung bulb nhk. i dont know kung reliable ung brand
    Dec 2014
    #517
    I think hylux is better(waterproof and vibration resistant). I think hidretrofit.net is also using it.
    Mar 2012
    #518
    Ok naman ang hylux and NHK. I don't think na sisirain ni angelo ang name ng shop nya by offering unreliable items. Pero syempre iba talaga ang performance and lifespan ng oem spec na bulb and ballast. But even the oem spec ay may mga lemons din pero mas less if compare mo sa mga aftermarket. Also may warranty ka so ok lang.
    Oct 2009
    #519
    Another thing to consider is if may naka abang na taguan ng ballast yung car, if OEM gagamitin kasi hindi ito water proof. Yung hylux daw water proof na siya.
    Mar 2012
    #520
    Quote Originally Posted by mousemouse View Post
    Yes, yan ang downside ng oem ballasts. Since specifically designed sila for a certain headlight which only accepts specific ballast mount to seat properly for it to be watertight. Unlike sa mga aftermarket which you can mount anywhere dahil most(if not all) of aftermarket ballasts ay potted ang internal circuits nila.
Planning on getting an HID retrofit
