Results 61 to 70 of 94
- 54,226
June 7th, 2023 12:25 PM #61i stand and squat some distance in front and a little to the side of the vehicle at night, mimic-ing oncoming traffic, and see if the glare is acceptable. i adjust accordingly, if possible.
LED is brighter than filamented bulbs.
uncontrolled glare that may be tolerable using filamented bulbs, can become uncomfortable when using LED, using the same reflector.Last edited by dr. d; June 7th, 2023 at 12:28 PM.
June 7th, 2023 07:43 PM #63
Tagal ko nang nag experiment sa best combination ng led, super bright halogen bulbs sa mga sasakyan kong naka reflector ang headlights. Isa lang ang ending, I upgrafed them all to HID with projector. 25-35k stage 2 to 3 compared sa 7 -15k na leds na sabog naman ang ilaw kahit anong adjust pa gawin. Mukha lang maliwanag yan kasi nasa city tinetest, daming source of light sa city roads, test moyan sa provincial roads dun mo makita its no better even worse sa stock halogen. So kung reflector headlight mo and you want better visibility go for hid with projector lens.
- Feb 2014
- 2,697
June 9th, 2023 02:20 PM #65yeah i tried those H4 LEDs (novsight). thin single-row LEDs (domeless) to simulate the length of glowing filament. non glaring but they don't seem to be any better than stock halogen, maybe even a bit worse so i'm back to the stock halogens
though i wanna try out these aux lights for motos. bottom part is the low beam which has a pretty good cutoff. then wire them up to light up concurrent w/ your stock high and low beams, respectively
June 9th, 2023 03:40 PM #66
- Feb 2014
- 2,697
June 9th, 2023 06:48 PM #67
June 10th, 2023 08:17 PM #68
Are they still making Nighteye LEDs? They rebranded to Novsight I believe around 2017.
Old stocks / older gen units?
June 11th, 2023 01:07 PM #69
- 54,226
June 11th, 2023 04:02 PM #70
Anong Chinese brand na ba ang available sa market? Yung Leoch brand may nakita na ko post sa FB....
