Results 31 to 40 of 94
- Jan 2017
- 429
May 26th, 2018 10:00 PM #31
May 26th, 2018 11:13 PM #32
Yes seperate adjustment ang each HL. And yes sa headlight assembly mismo may nakalagay na adjusting screw for horizontal and vertical alignment and also for fine tuning of each HL.
Though sa ibang vehicle like for example mine meron headlight leveling features to adjust the level of the cut-off pero para lang yan mag offset ng cut-off ng HL if mabigat cargo ko sa likod and both HL move at the same time.
- May 2018
- 5
May 27th, 2018 02:58 PM #33Based on pricing from *Glenn_duke's post, I think we will prepare at least 15K to 20K max but we prefer to have it installed by a highly recommended professional than DIY. Wont touch anything dont know nothing about [emoji28]
Thank you so much for the suggestion.
We will read about it. How much is HID projector retrofit?
May 27th, 2018 05:47 PM #34
for 15k you can have an entry level set-up for that dagdagan mo konti ang 20k mo mid-level na yan kay ang angelo magtoto of redline autowoks. Si Jut na mods dito sa redline din pinagawa HL nya.
If you go with xenon concepts ask for the FX-R projectors or at least G5-R. G5-r is mas madali ang installation dahil bolt on. Fx-r naman is they have to cut the reflector bowls and di kana pwedeng bunalik sa stock if ever you want to. But fx-r for me has better width.
For some even the Q5 is more than enough na and wont care the difference between oem spec or aftermaket projectors. For me, if budget permits gusto ko nanaman palitan yung gen1 philips xvc1 into gen2 after nakita ko meron na available bulbs sa firedrake
May 27th, 2018 06:27 PM #35
Yes I had my Mazda 3's headlamps retrofitted through Redline Autoworks. The HID is turning 3 years old but still works very well.
I would also recommend HIDretrofit.net by Gary Quizon - he did the foglamp retrofit for our CR-V and output is so much better than the car's stock LED headlamps.
- May 2018
- 5
May 27th, 2018 07:19 PM #36Thanks guys. I checked their FB page and this FAQs very helpful
HID Retrofit FAQs (Frequently Asked Questions)
- Jan 2017
- 429
May 27th, 2018 08:20 PM #37
May 27th, 2018 08:53 PM #38
Depende kung anong repairs ang ginawa sa projectors. If ginalaw ang projector which is mounted on the reflector bowl na may adjuster mount sa likod banda which is also connected sa adjustment screw sa labas, SOP na yan na mag re-align ulit after re-assembling the HL just to make sure na tama ang alignment.
Anong repairs po ba ginawa sa isa nyong HL?
- Jan 2017
- 429
May 27th, 2018 10:20 PM #39
- Jan 2017
- 429
May 27th, 2018 10:27 PM #40Eto pla ung light pattern. Mali ba or what? Pls dnt judge me haha just making sure ayoko makasilaw
And also edit option is not allowed anymore :grin:
Problems with viewing Tsikot on non-Chromium...
