Latest on my car,
OEM Bixenon 65mm Projector Fogs
Let's wait for gary to post pics of the outputs..
*Thanks again gary, now DRL's.. Hmm..![]()
denki: pwede para Euro dating, sa fogs mo pwede mag retro nyan or HID projector for your fogs! hehehe.
brell: as always, a pleasure to retro your rigthanks!
I did this Fozzy a year back and I returned to put new amber LEDs and also to re-wire the inner to switch ON/OFF using stock fog lamp switch. As usual, I am still drooling over this ride.
sir Gary ask ko lang po if meron po bang projector headlamp for suzuki alto?
interested po ako lagyan ng projector po ung alto ko. at magkano po sir
glntVR: bro T10 lang etong LED na eto. No need to open the HL. I installed 2.5w amber led na peanut type. Hanap ako pix nung T10 na LED ko wait lang.
sir, possible ba ma-retrofit yung lancer ck/pizza na one-piece headlight?
ganito sample picture:
kung possible sya, pa-quote po via PM kung low beam lang ang ipapa-retrofit.
thanks!
vrl: pwede bro and mukhang your hl needs restoration na rin. sent you a PM
junkun: suggestion ko sa loob ng fog lights mo para Porsche style na DRL. I can retrofit 3 OEM leds sa loob nung fogs and wire it as a DRL. Ganda nyan
chikselog: bro I suggest getting plug in LEDs for these. I have T10s and 7443 bulbs na LED.
installed my aftermarket (bolt on) projectors sa dalawang Civic before ako mag break and eto results.
LO
HI
To explain a bit about this setup. I have worked with many types of "bolt on" projectors and to tell you frankly, bolt ons are not really bolt ons if you want to do it correctly. Many of these projectors need some modifications to correct mounting and also to maximize output. One might say na ok naman as is, pero sa akin, nabuksan mo na rin lang, bakit di mo pa ayusin and mount it properly and get the max output from the projectors. I have also tried and tested many "bolt on" projectors and the one I am using now has the best output in terms of width and intensity. I modify these projectors to get the best output and mount it properly sa headlight. The harness and the sealant for this setup is also the same as my oem package so everything in the setup is designed for long term use.
Ampogi nung headlights nung EG ! How much yung bolt-ons, bro ? Hehehe.
renzo: ganyan pala gusto modenji yan na lumang model, I dunno kung meron pa ganyan na headlamps ngayon. PM na lang kita
junkun: tatlong oem LEDs na diamond formation inside your existing fogs, ganun itsura nun. diko makita yung FD na ginawa ko. mga present Porsche naka ganun na DRL, search mo sa net.
