Page 204 of 239 FirstFirst ... 104154194200201202203204205206207208214 ... LastLast
Results 2,031 to 2,040 of 2382
  1. #2031
    Quote Originally Posted by joms View Post
    sir gary, any update sa question ko? thanks
    bro pls refresh my memory, ano pala uli yun question mo?
    Jul 2004
    #2032
    Quote Originally Posted by garyq View Post
    sir gary, can i ask lang. If in case I get the level 3 package for my santa fe, then after a couple of years nasira either the bulb or ballast, how much po yung cost to have it replaced? I hope hindi naman the full cost again.
    thanks
    Aug 2012
    #2033
    Hi Gary, medyo "nadidiliman" na ako sa Stage 3 bi-xenon na ginawa mo (blue ASX). Magkano kaya magpa-upgrade to a quad (another pair of bi-xenon projectors)?
    Dapat yata nagpa-quad na ako nung una pa. I think my "hi" reflector bowls are large enough for another projector set. I might go for it if the price is not too prohibitive. Thanks.
    Norman
    Sent from my Galaxy Note
  4. #2034
    thanks
    Yes you can change just the bulbs and ballasts. FYI, for my stage3, the first one I installed was 2009 and up to now wala pa akong napapalitan na bulb na Philips 85122+. Sa ballasts less than 2% sa stage3 ang return rate ko coz oem naman yan. This means sa 100 ballast na nakabit ko, less than 2 pcs ang bumabalik na meron manufacturing defect.
  5. #2035
    Quote Originally Posted by Pipefish View Post
    Norman
    wouldnt suggest it. a 70mm fog retrofit is better. more than 90% of your driving nasa LO ka and 10% lang you use the HI. Sayang to have bixenon projectors dun. Sa fog retrofit, pwede lagi naka ON kasabay ng LO projectors.
    Aug 2012
    #2036
    Hi Gary, thanks for the advice. Makes sense. Akala ko kasi pwedeng ALWAYS ON with LO 'yung HI, tapos tataas lang ang buga pag naka-high switch. Hehe. Can you PM me the price of a fog-lamp retrofit? My halogen fog lamps now have H11 connectors. Thanks.
    #2037
    sir Gary, i just txted you sa smart mo inquiring price for fog retro fit for santa fe '10 model (2.5 generation). looking forward to your reply. thanks
    #2038
    Sir Gary, salamat noong Sabado and pasensya na rin sa short notice. Hope to meet you soon sir. Will email you something din. Thanks sir.
    Jun 2012
    #2039
    hi sir gary can u send me a quotation for 2012 gls v montero on all 3 stages and any suggestions? thanks!
  10. #2040
    mar: sent you a PM
    a monster T6
    stage2 with DRL module
HID Projector Retrofits by garyq
