Results 1,031 to 1,040 of 2382
- Aug 2011
- 374
November 15th, 2011 02:52 AM #1031Ano po magandang gamitin na bulb sa high beam pag naka HID na yung low?
- Aug 2011
- 374
November 15th, 2011 03:06 AM #1032Sir Gary, hindi naman affected yung output ng light kahit naka DEPO lang basta naka retrofit diba?
- Dec 2002
- 2,335
November 15th, 2011 08:53 AM #1033gts: get Osram NB or Philips XP/XV. Depos are good aftermarket HL, di naman affected basta retrofit mo para hindi sabog yung output nung HID bulb.
- Sep 2008
- 581
November 17th, 2011 09:37 PM #1034Gary, I am not sure if this has been asked before; Can you enlighten us the differences in light output in the choices of the projector clear lenses? In your personal opinion, what clear lens so far has given you the best performance?
- Jan 2010
- 8
November 18th, 2011 04:35 PM #1035
- Dec 2002
- 2,335
November 18th, 2011 05:53 PM #1036jake: you mean the glass lens of the projector?
gcl: sent you a PM
2010 Navara
- Sep 2008
- 581
November 18th, 2011 09:50 PM #1037That is correct Gary, the glass lens of the projector; as I have read that the lens means a lot too in the projection of light.
- Feb 2003
- 1,033
November 18th, 2011 10:51 PM #1038
- Sep 2008
- 581
November 19th, 2011 12:12 PM #1039Gary, what is the difference between halogen projectors which are found in OEM's like the Monteros and the retro projectors?
- Dec 2002
- 2,335
November 19th, 2011 02:57 PM #1040jake: the projectors I use have clear glass lens already. Before, I use to install TSX and TL but now there are other projectors than can perform well (even outperform some oem projectors) and these oemprojector have dimpled or frosted lens and you need to swapped out the lens to maximize the output.
halogen and hidprojectors: different design.
jiggs: thanks
Oh I see! That explains why the brembo pads seem to have a different design. The original Akebono...
Brake Pad Thread [Merged]
