Page 103 of 120 FirstFirst ... 3539399100101102103104105106107113 ... LastLast
Results 2,041 to 2,060 of 2385
  1. #2041
    Some teaser pix of our Raptor inspired retrofit for the T6 Ford Ranger. We removed the reflector bowl, made custom mounts for the projectors to offset the position to the outer part of the HL, like the Raptor and made custom bezels to cover everything up.
    Aug 2011
    #2042
    Sir pa pm kung magkano retrofit montero stage 2 and 3.
    Sent from my Lenovo P770 using Tapatalk 2
    #2043
    After a couple of nights and 204 pages, I finally finished reading the whole thread! Whew... Very informative and learned a lot from this. Sir Gary, Kudos to you and your team!!! Lupit ng mga gawa niyo. Sir pa quote lang muna ako how much po hid fog retrofit for 2010 Strada? Would you also be willing to do some custom tail lights for my bumper. Will email you sample and maybe you can give throw me some ideas and how much it would cost. Pleas PM me the cost. Thanks.
  4. #2044
    mjlu: thanks bro, ang tyaga mo PM kita
    Pics of projects last month:
    Apr 2010
    #2045
    Gaganda naman. Meron din po ba ito for Vios 2nd Gen? Thanks.
    Sent from my iPhone
  6. #2046
    #2047
    * garyq : ok lang kasi dami naman pics. Kaya di nakakabugnot bashin. Actually nakakainggit nga dahil sa ganda ng mga setups. Emailed you the pic na pala. Thanks again.
  8. #2048
    oem package for Subaru Forester SG 2007 including LED custom daylight running lights
    Jun 2012
    #2049
    boss gary pwede pa post nung oem style na drl na nasa loob ng HL ng montero? un ba ung parang parenthesis lang sa gilid ng shroud? TIA!
  10. #2050
    Quote Originally Posted by mar04 View Post
    yup tama. dun lang pwede maglagay ng DRL na mukhang original pa rin.
  11. #2051
    Hyundai Elantra/Avante MD 2014
    OEM package
    Aug 2005
    #2052
    Hi Gary, saw your projects and i'm interested. Can you pm me the price and the specs of the stage 1, 2 and 3 retrofit for the 2014 Montero? Tia
    Sent from my iPhone using Tsikot Forums
  13. #2053
    gabo: sent you a PM
    Vehicle specific DRL/fog light assembly for Hyundai Accent 2012-13. Dual intensity output for DRL function and parklight/driving light function. Complete with auto module and wiring harness
    Aug 2012
    #2054
    Quote Originally Posted by garyq View Post
    gabo: sent you a PM
    Huwat, no projector lens? Mortal sin. Hehe. Gary, question: for fog light throw (HID projector), how many inches should it be lower than the normal head light cut off? OK lang rin ba kung kapantay lang ng head lights? Thanks.
    Aug 2012
    #2055
    To rephrase my question: How many inches should the fog light cutoff be from the head light cutoff and at which specific distance from the wall? Thanks.
    EDIT: I know that head light/fog light aiming is a complicated issue (lamp axis height, etc.) and I'm probably oversimplifying it. But I was hoping you could give me a rough and general idea. Failing that, I just might go back to you for a fog light retrofit. Haha.
    Sent from my Galaxy Note
    Aug 2012
    #2056
    OK, here's a more intelligent question: How many inches below the fog light axis/center should the cutoff be at 25 feet? 2 inches? 2.5 inches? 3 inches? What do you normally use? Thanks.
  17. #2057
    same way you adjust the HL. 25ft away on flat surface, measure from ground to middle ng fogs, project to the wall and this is your cutoff height. But with your stock fogs you can only approximate this.
    Aug 2012
    #2058
    Thanks, Gary. So no need to measure 1.5"-4" below the center of the fog light? Anyway, napapagod na 'ko mag-DIY. I managed to convert the projector from my stock head lights, after your retrofit, by sealing the holes. I have a nice cutoff (and the projector is big, maybe about 2.5") but the projector is not stable. I have a feeling pag nalubak ako uurong siya. Haha.
    Aug 2012
    #2059
    Gary, 'yung fog light retrofit mo ba kasing-sharp ang cutoff ng sa head lights? At gaano katagal gawin? May stages din ba 'to (1-3) o isa lang? Kasing-liwanag ba ng H1 mo 'yung D2S Stage 3 ng head lights ko at same color? Thanks.
  20. #2060
    yung 70mm yes, very sharp but more important, kasing intense and wide yung output. isang package lang. 4300k din
HID Projector Retrofits by garyq
