View Poll Results: Have you encountered problems with E10 blended gasoline?
- Voters
- 72. You may not vote on this poll
No problem with E10 gasoline
19 26.39% -
I have reduced fuel mileage with E10
37 51.39% -
I have reduced engine power with E10
25 34.72% -
My engine is not compatible with E10.
15 20.83% -
I have other problems (not listed) with E10.
6 8.33%
Multiple Choice Poll.
Results 91 to 100 of 132
July 17th, 2009 10:44 PM #91
my engine is not compatible with e10 fuel. in our place, it's hard to find gasoline stations offering non-e10 fuel.that's why my dad is planning to sell it.
July 20th, 2009 08:52 AM #92
Bara-bara na naman ang labanan dito at ang implementasyon ay hindi pinag-aaralang mabuti dahil walang information dissemination drive, which means officially engaging the car manufacturers para alam ng mga tao ang puwede o hindi puwedeng sasakyan.... To each his own na naman tayo rito.....
8303:dishwash:
July 21st, 2009 10:56 AM #93
grabe talaga pagkakaiba sa hatak pag e10 ang kinakain ng engine..sa tapak pa lang at pag galaw ng speedometer ramdam mo ng e10 yung kinakain ng engine..ang hina ng hatak kailangan pa diinan tapak sa gas pedal para umarangkada..nakakapanibago talaga pag galing ka ng premium at nag shift ng e10..
to e10!!
August 29th, 2009 07:38 PM #94
wow, buti nahanap ko 'tong thread na 'to. meron po bang '09 jazz owners dito?
only had my jazz for about two weeks at mula paglabas ng casa e E10 ang nilalagay ko. so far nakaka-dalawang karga pa lang ako. parehong shell E10, kasi yung super unleaded pala nila E10 na. ngayon nasa kalahati pa lang yung nagagamit ko sa last full tank.
napansin ko nga yung pag sinok ng makina pag nakahinto. ubusin ko lang yung E10 tapos try ko naman yung XCS.
August 30th, 2009 07:56 AM #95
pahabol na tanong, kelan pwedeng magkarga kung magpapalit ka ng fuel? meron pa kasi akong half tank ng E10 shell super unleaded. gusto kong i-try yung XCS. pwede ba silang maghalo sa tank?
TIA!
August 30th, 2009 08:15 AM #96
Yeah pwede sila maghalo pareho lang namang unleaded yan eh. Basta hindi ka naglagay ng diesel ayos ka na...
August 30th, 2009 01:32 PM #97
The real time bomb is August 2010. By law (Biofuel Act) ALL vehicle fuel will be 10% Ethanol. No need to place the E10 sign because ALL FUEL will have 10% ethanol.
Unless the law is repealed.
The real apocalypse follows afterwards. There are now initiatives to have E15 and E20. This will be the ultimate bomb and I doubt any older car (that is older than 10 years) will survive without major modification.
Additional cons of E10 - shelf life. Parang 3 months lang ata. You cannot leave fuel for more than 3 months safely because of the water bonding problem of E10.
Tips on E10 - always FILL YOUR TANK. A tank kept at full often will have LESS WATER for E10 to absorb.
- Sep 2009
- 1
September 3rd, 2009 11:24 AM #98My Car is a Kia pride LX 1995 model.
Since I first tried using e10 from petron and because hindi na daw available ang pure unleaded gasoline nila na xtra. First thing I experienced is reduce power, mahina ang hatak.2). increased fuel consumption. so I adjust the air fuel combination screw to let more fuel in. lumakas ang hatak. Then after about one month of using e10, The carburator gas overflow into the mixing chamber, naturaly nalunod ang makina sa gasolina, tumirik in the middle of the road. Nasa mind ko agad na baka sira ang metering valve or float valve ng carburator, hindi sya nagsasara kaya nag overflow.The carburator is still original, never been repaired. So I open up the carburator after I manage to let it tuck back to my home. The overflow metering valve is made of rubber, now It come to my mind na baka me kinalaman ang e10 dito because of what I read on this forum na it affects rubber parts. so All I did was increase the spring tesion sa metering valve para magsara kahit hindi pa half level and gaoslina sa viewing glass. put it back and ok nanaman ang makina.
Just to make sure, I switch to XCS for now until I am sure na e10 is the culprit.
Does anybody in this forum experienced this problem???? Share it.
September 3rd, 2009 11:32 AM #99
^^^ Your ride is not geared for e10 bro.... Carburetor pa kasi iyan.....
8601:matrix:
September 3rd, 2009 11:46 AM #100
I have serious doubts if the people in Senate and Congress even grasps the problem of E10 gasoline because they all ride in big SUVs and sedans that are either new or relatively new.
For the typical working class person who owns a car, there is a big chance that the car is ten years or older. So it will be a big problem if all gasoline will be ethanol blends.
Currently, the only viable solution would be to upgrade the car to Auto-LPG which would by-pass the ethanol compatibility problem in older cars.
That's what he actually did. He also retrofitted an eps to his 1970s era beetle. Btw, now...
A/c
