View Poll Results: Have you encountered problems with E10 blended gasoline?
Voters
72. You may not vote on this poll
  • No problem with E10 gasoline
    19 26.39%
  • I have reduced fuel mileage with E10
    37 51.39%
  • I have reduced engine power with E10
    25 34.72%
  • My engine is not compatible with E10.
    15 20.83%
  • I have other problems (not listed) with E10.
    6 8.33%
Multiple Choice Poll.
Page 5 of 14 FirstFirst 123456789 ... LastLast
Results 41 to 50 of 132
    #41
    Mga sirs:
    e quote ko lang nabasa ko sa isang site:
    “As a solvent, ethanol attacks both the metallic and rubber based fuels lines, and other fuel system components.
    “Ethanol also has an affinity to water that can result in corrosion of fuel tanks and fuel lines. Rust resulting from this corrosion can ultimately block the fuel supply rendering the engine inoperable. Water in the fuel system can also result in the engine hesitating and running roughly.”
    Actually po meron syang pros and cons based sa site na nabasa ko. di ko lang po ma post dito lahat kse medyo mahaba. At di ko rin ma post site kse bago lang po ako dito sa tsikot. Pero sa pagkakaintindi ko po, ang pinaka pro sa kanya :
    1. mas mura and
    2. mas earth friendly kse other fuel.
    hope this info could help all of us.
    Aug 2008
    #42
    grabe mura ngaun ng E10 35.07. i just filled full tank. 50 liters 1.7++K lang. pang buong pasko na'to. i only consume about 30 liters/month
    Aug 2007
    #43
    Quote Originally Posted by benoy View Post
    Mga sirs:
    1. mas mura and
    Yung pros niya actually tend to be part of the question in this thread:
    1) Mas mura nga ba if your car's mileage goes down?
    2) Although CO2 levels go down, Ethanol based fuel is known to produce increased amounts of other gases such as asthma-inducing Ozone.
    #44
    piso na lang lamang ng unleaded sa diesel. at mas mura naman ang E10 sa unleaded. mas mura pa tuloy ang E10 kesa sa diesel for private.
    btw pwede ba E10 sa 7K carb engine ng Tamaraw FX ? TIA
    May 2005
    #45
    ayos nga e10 eh, mas mura sa diesel... medjo di pa ganun ka reliable yung carburador sa ethanol... wag na muna para safe
    #46
    yun, kagaya nga ng tanong ni bro xto, pwede ba sa 7k carb engine fx ang e10? sayang naman kasi yun malaking matitipid pag gumamit ng e10
    Jun 2005
    #47
    ^^^^ sagot dun sa carb engines.
    Jun 2006
    #48
    just filled up kanina with e10 on my almost empty tank. 500 pesos =14.30 L.
    What i noticed agad mas hirap cya bumatak di tulad when i use regular unleaded.
    fuel consumption just the same.
    but tingnan ko ulet bukas baka inaantok lang me kya magaan tapak sa gas.
    Nov 2006
    #49
    Carb engines could not handle the ethanol content on E10, it is only good on EFI engines.
    #50
    thanks Taurus and C#*RD
E10.. Yes or No?
