View Poll Results: Have you encountered problems with E10 blended gasoline?
- Voters
- 72. You may not vote on this poll
No problem with E10 gasoline
19 26.39% -
I have reduced fuel mileage with E10
37 51.39% -
I have reduced engine power with E10
25 34.72% -
My engine is not compatible with E10.
15 20.83% -
I have other problems (not listed) with E10.
6 8.33%
Multiple Choice Poll.
Results 41 to 50 of 132
November 30th, 2008 03:20 AM #41Mga sirs:
e quote ko lang nabasa ko sa isang site:
“As a solvent, ethanol attacks both the metallic and rubber based fuels lines, and other fuel system components.
“Ethanol also has an affinity to water that can result in corrosion of fuel tanks and fuel lines. Rust resulting from this corrosion can ultimately block the fuel supply rendering the engine inoperable. Water in the fuel system can also result in the engine hesitating and running roughly.”
Actually po meron syang pros and cons based sa site na nabasa ko. di ko lang po ma post dito lahat kse medyo mahaba. At di ko rin ma post site kse bago lang po ako dito sa tsikot. Pero sa pagkakaintindi ko po, ang pinaka pro sa kanya :
1. mas mura and
2. mas earth friendly kse other fuel.
hope this info could help all of us.
BANNED BANNED BANNED
- Aug 2008
- 1,099
November 30th, 2008 11:41 PM #42grabe mura ngaun ng E10 35.07. i just filled full tank. 50 liters 1.7++K lang. pang buong pasko na'to. i only consume about 30 liters/month
- Aug 2007
- 675
December 3rd, 2008 10:24 AM #43
December 3rd, 2008 10:44 AM #44
piso na lang lamang ng unleaded sa diesel. at mas mura naman ang E10 sa unleaded. mas mura pa tuloy ang E10 kesa sa diesel for private.
btw pwede ba E10 sa 7K carb engine ng Tamaraw FX ? TIALast edited by XTO; December 3rd, 2008 at 10:48 AM.
December 3rd, 2008 11:07 AM #45
ayos nga e10 eh, mas mura sa diesel... medjo di pa ganun ka reliable yung carburador sa ethanol... wag na muna para safe
December 3rd, 2008 11:40 AM #46
yun, kagaya nga ng tanong ni bro xto, pwede ba sa 7k carb engine fx ang e10? sayang naman kasi yun malaking matitipid pag gumamit ng e10
December 4th, 2008 09:08 PM #48
just filled up kanina with e10 on my almost empty tank. 500 pesos =14.30 L.
What i noticed agad mas hirap cya bumatak di tulad when i use regular unleaded.
fuel consumption just the same.
but tingnan ko ulet bukas baka inaantok lang me kya magaan tapak sa gas.
December 4th, 2008 09:31 PM #49
