Results 81 to 90 of 148
January 12th, 2010 08:19 PM #81
If you don't care about the 26k difference. Get the jazz. Yellow or White
Pang-babae.
But if medyo in doubt ka, syempre City Tafetta White.
January 12th, 2010 08:38 PM #82
either the Jazz 1.5 or the City 1.5 both in Tafetta White shade is very much ok.
but the Suzuki Swift is also a very nice car although rear leg room is not that roomy.
January 12th, 2010 08:44 PM #83
:dito:
And since its a suzuki. After-sales sucks. And the resale value will suffer much. But despite the negative comments about it, the swift isn't a bad car either, easy to modify.
Though, I still don't believe when someone claimed a 6 second run bet. 0-100kph. :nono:
January 12th, 2010 09:06 PM #84
January 13th, 2010 10:22 AM #85* tsupermaria - a car and a bug huh? Very good! you know what to say to a woman
So tempting!
* aejhayl17 - tumpak! I won't let my BF drive the car all the time kase baka maging cause pa ng break up! haha :D
* archie123456789 - thanks, I iwll really scrutinize. Everytime kse I go to the showroom na mesmerize nalang ako and forget to check nook and crannies eh.
January 13th, 2010 10:32 AM #86
* water - thanks, however my SA said do not get the yellow one due to poor resale value. Ako naman not considering that kase baka magsawa ako bigla sa color. Sa umpisa lang cute.
* niwde11 - thanks for the tip. I will ask around again.
* tidus1203 - change of heart? Bakt nga ba 6 out of 10 white ang boto? Kase bagong labas yung white? Ganda din ng whote na Jazz
January 13th, 2010 10:42 AM #87
* Type 100 - thank you for your input. My nose bled! joke
I don't really need the speed however, the 1.5L variant will the added HP and "hatak & hataw" feature will come into good use when I drive it to Baguio or whenever I come across steep slopes and climbs.
* jut703 - thanks Jut! Will keep that in mind.
* renzo_d10, Leoxe and GH - thank you thank you for all your input. Konting tiis nalang, I will make a decision na once I get all the computations.
January 13th, 2010 11:05 AM #88
The L13A 1.3L engine is actually a fine motor, especially now with VTEC in the Jazz - just not at its best mated to the automatic and its economy-biased programming. It's too eager to upshift to the next higher gear.
It's not all about speed either. When you have to overtake a slower car on a two-way road (and trust me, you will have to do this at some point), you'll want to minimize your "time exposed to danger" (i.e. to oncoming traffic) by performing the maneuver as quickly and as safely as possible, holding on to the acceleration as long as you can. In this circumstance, the last thing you want is a transmission that's overly eager to upshift.
You can learn to adapt and make the Jazz 1.3L A/T obey your will, but it's a little bit harder than it needs to be.
January 13th, 2010 11:45 AM #89
The 1.5L has a paddel shifters so you can downshift at will pero sa 1.3L its tricky. Of course M/T is still the best sayang walang 1.5L na M/T ang Jazz and City...
January 13th, 2010 01:18 PM #90
brother Tidus - ayoko nga mag drive ng MT... katamad!
* Type 100 - oh yes, now I get your point. Medyo matagal pa before I will have the guts to overtake during long road trips
if you purchased your car recently... nasa OR kung hanggang kelan valid yung registration mo. If...
1st LTO renewal after 3 yr registration
