Page 61 of 80 FirstFirst ... 115157585960616263646571 ... LastLast
Results 1,201 to 1,220 of 1594
    Ito sino makakexplain parang science ala dr d, jut, niky, egan
    Bakit pag manual trans simula nung 80s 90s ilan klase kotse na dumaan eh hindi pinapalitan gear oil.... No problem....
    Meron time pala na nagpalit nung nagkaleak lang. Bumili lang ako gasket/oring eh ayos na ulit..
    Pero ngayon mga current user manual iniidicate na palitan mt fluid?????? May pinagbago ba components mt or kailangan lang quomota ang casa?
    Kaya natutuwa ako sa mt eh good for the environment..... You dont throw oil.....pang lifetime na gamit..
    Jan 2009
    #1202
    Who's to say that the transmission is still tip-top if you don't change MTF? It may feel that it's working just fine but in fact, the gears may already be swimming in its own filth (floating metal particles and shavings) as a result of wear and tear.
    Granted that M/Ts are a bit more forgiving than A/Ts, you still need to change the MTF as required in your manual and/or fix problems when symptoms arise.
    #1203
    MTs are built to larger tolerances, compared to ATs. someone once said, "ATs are built to swiss-watch-like tolerances". overkill description, maybe, but google some pictures, po, and you will get the general idea.
    as such, ATs are more sensitive to lubrication issues.
    some of today's casas do have this reminder to "change this... change that..." as part of their customer service. they even call or text me, as reminder! it's easier now for them to keep track, because of computers. there are many car owners, kasi, whose idea of car maintenance, is to replace the pine-tree car freshener hanging under the rear view mirror. heh heh.
    yung ibang kotse naman, ay naka-program na sa car's computer, to remind owners that it is time to change this or change that. hindi ito casa-level decision. manufacturer's decision level ito. casas are simply "benefiting from the situation", if one would like to put it that way.
    the only time i replaced my MT's gear oil, was after ondoy. i had it checked, and it looked like coffee latte. definitely water-contaminated!
    and yes, oil does not die. but it does get contaminated. and its additives that make it a better oil, do deteriorate.
    Jan 2009
    #1204
    One obvious reason why A/Ts require relatively more attention than M/Ts is because of the built-in clutches. These clutch bands don't respond well to metal shavings coming into contact with friction surfaces. If this goes unchecked for a significant amount of time, catastrophic failures becomes inevitable.
    Another reason is due to the complexities of the oil passageways, solenoids, valves, fluid pump and whatnots, that can get clogged up or damaged.
    All these in the name of driving convenience. But for as long as you take care of an A/T, it should provide you trouble-free operation for the life of the vehicle.
    #1205
    Sorry if newbie question pero how do you drive an automatic?
    Our family recently acquired an A/T vehicle kasi. Although, I know some basic stuff about automatic transmission vehicles like nakapag drive na ako before (via test drives sa mga auto show/events). I'm used in driving a M/T transmission na vehicle and yes, medyo naninibago ako with the A/T one. Anyways, na drive ko naman yung car from the casa to our house safely. I know lang naman na you just put it in "D" then magdrive ka na. But let's say if i'm going to climb hills or something steep, sapat na ba na nasa "D" lang? or let's say susulong ako sa baha, "D" lang din ba dapat? There's an "S" option and it's for me to control the gear changes pero I'm quite afraid to use it haha. Nasanay lang kasi ako M/T na I have control over the gears and I really don't think I have to go to driving school again (I learned kasi how to drive using a M/T transmission).
    And last thing, may alam ba kayo na magandang article about this? haha I'm really sorry if parang ang basic or parang "huh??" ng question ko
    #1206
    Quote Originally Posted by Kapitan Sibuyas View Post
    Ganyan din naisip ko noon when I got my first AT car. Nasanay din ako at naghahanap ng clutch ang kaliwang paa at weird na walanb ginagawa ang kanang kamay. Don't worry, kapag inclined paakyat hindi yan aatras gaya ng MT. Kung feeling mo bitin or hirap siya umakyat, put it on S or manual mode and shift to a low gear. But normally if you have a strong enough engine, leaving in in D is fine. Same sa baha. After a week masasanay ka rin.
    Sent from my P01MA using Tapatalk
    Jan 2009
    #1207
    On about 99% of your driving, just leave it in D. On situations when you need extra torque like when driving up inclines or hills, just press on the gas pedal and the ECU will tell the A/T if it needs to downshift automatically or not. No need to shift to S or manual mode in most cases.
    The Sports/Manual mode is marketed as a way to allow the driver to choose his own shift points, typically to achieve faster acceleration. However, it may not always be the most fuel efficient method.
    If you're a new A/T driver, be wary of what's known as A/T creep whenever you are in any of the forward or reverse gears. This is a normal behavior on A/Ts but can catch longtime M/T drivers by surprise if they're not used to it.
    Go for A/T.
    #1209
    put it in D and drive it like a bumpcar. without the bumping, of course. put it in N when idling in traffic. i turn off the engine if the traffic is bad or the traffic signal is slow in turning.
    i have been driving AT for over 5 years now, and i haven't yet been stumped by it.
    Sep 2005
    #1210
    turn off the engine on traffic? diba mas malakas sa gas yun pag ni start mo ulit..
    Apr 2008
    #1211
    Its really easy to drive an AT car. Remember to always shift to N when stopped in traffic to prevent premature brake wear and lessen chances of accidents. When parking on an incline, always remember to engage the handbrake before shifting to P to prevent transmission damage. Most AT's require a fluid change every 40tkms.
    Sent from my SM-G900I using Tapatalk
    Apr 2017
    #1212
    A/T for city driving. M/T for highways, expressways. The comfort of having an AT in metro manila probably over weighs the expenses or sporty feel of a MT.
    Sent from my SM-G928V using Tsikot Forums mobile app
    #1213
    Quote Originally Posted by MatchuPichu0324 View Post
    May mga AT naman na sporty, in fact sobrang sporty pa kaysa usual MT. Depende sa sasakyan na lang yan.
    #1214
    an engine turned off does not consume fuel. but upon starting, some engines settle immediately to its usual idling rpm of 700-900, while other engines, like mine, first go to a higher rpm, then go down slowly to the usual idling rpm.
    what i did, was to observe how high my starting rpm would go, and how fast it would settle to the usual idling rpm of 700-900 per minute.
    with those in mind, i figured, rightly or wrongly, that my break-even stoplight time, was 30 seconds.
    if the stoplight lasts more than 30 seconds and i turn off my engine, "i am ahead".
    if the stoptime is less than 30 seconds and i still turn off the engine, "i use up more fuel" when i start the engine than if i just kept it running.
    it keeps me entertained.
    Apr 2017
    #1215
    Sporty feel, yung kumakambyo ganun.
    Apr 2008
    #1216
    Di ba mainit kapag ginawa mo yan doc? Summer na summer pa naman ngayon. 😆
    #1217
    Quote Originally Posted by GTi View Post
    Di ba mainit kapag ginawa mo yan doc? Summer na summer pa naman ngayon. ��
    ok lang sakin.
    kuripot trumps everything else!
    but one has to be sure, he has a good battery! isang beses, hindi ko na ma-restart! buti na lang, may dalawang pusher na dumaan, at yung MT ang dala ko... heh heh.
    tuloy-tuloy ako sa battery store.
    #1218
    Hirap ako makipag gitgitan using an AT. Probably psychological. I still prefer driving a manual.
    #1219
    Puwede naman paddle shifter. For me, sporty means quick steering, ample grip, firm suspension, very good throttle response, and decent power-to-weight ratio.
    Sorry but kung mabagal at unresponsive yung kinakambyo mo, di sporty yun.
    #1220
    i agree with you. and i do not think it is psychological.
    those who are so very used to MT, will find the AT, a little wanting. "no fingertip control".
    i used to gitgit a lot, back when i was driving a korean... a kia besta.
    "sige! gusto mong makipag-bangga-an sa besta ko! lancer kah..! mura lang pa-gawa nitoh!"
Battle of the Transmissions: M/T vs. A/T
