Originally Posted by
oj88
To your original question, yes, you can shift down to D3 several seconds prior to overtaking, provided your current speed is still within the range of D3 so you don't over-rev your engine. Some vehicles would rev-match as you shift to a lower gear, especially those equipped with an electronic throttle, but if your vehicle has a mechanical throttle control, you will have to rev-match manually to maintain your speed.
The problem sometimes with just stepping on the gas pedal to trigger a downshift is the delay involved. Normally, you'd want to be already in a lower gear, rev-matched, as you time the overtake. This is referring to traditional A/T of course, not the sport/dual-clutch A/Ts that shifts almost instantaneously.
