Results 371 to 380 of 1594
January 7th, 2010 02:59 PM #371
bad trip ako kapag may mabagal na A/T car sa harap ko tapos paahon ang daan tapos naka-M/T ka.
no offense meant ha pero napapansin ko sa mga mababagal magmaneho (sa city not on highway) : Most of them drive A/T. Nagtitipid yata sa gas. Open road pero ang speed nasa less than 50kph.
January 7th, 2010 03:05 PM #372
January 7th, 2010 03:34 PM #373
Not true. Yung torque converter ang functional equivalent ng clutch sa M/T. Yung mga clutch packs sa A/T ay para lang sa linkage ng mga different gears (ie. 1st gear, 2nd gear, 3rd gear, etc.). Kapag nakahinto tapos nasa "D", yung clutch ng 1st gear naka-engage (walang slippage). Yung torque converter ang nagpo-provide ng slippage para hindi mamatayan ng makina.
January 7th, 2010 04:17 PM #374
oj88,
yes tell them. this is another area a lot of people have the wrong myth. they can go to www.howstuffworks.com on this and hopefully they will get educated and understand.
jick
January 7th, 2010 04:47 PM #375
BANNED BANNED BANNED
- Jul 2003
- 2,267
January 7th, 2010 05:04 PM #377
January 7th, 2010 05:07 PM #378
kalokohan...doing 50kph will never consume less than car cruising at 80-120kph with engine speed running only at 1500-2000rpm..
xty ko runs 100kph at 1800rpm...pero most of the time napapapisil ng madiin sa throttle di ko namamalayan 180-200kph na, lalo na kung napapasunod sa mabilis...si wifey lang nagpapaalala sa akin...hay (downside of having the gauge cluster in the middle)
January 7th, 2010 05:12 PM #379
in europe, 2010 model cars with automatic transmissions, the engine stalls or stops running when you step on the brakes and the car comes to a complete stop to save on fuel, then automatically restarts once you release the brake pedal and step on the accelerator. this is not possible with cars equipped with M/T. some hybrid cars are the same, it has to be equipped with A/T and/or operate on the electric motor or in some torque demanding situations, the engine and the electric motor propel the car
jick
January 7th, 2010 06:35 PM #380
Yup, it's more of driver attitude that dictates how fast or slow he/she drives, not the transmission type. Meron tao na walang pakialam na kahit masama ang kalsada, harurot pa rin. Yung iba, I can understand na maingat mag-maneho or iniingatan yung sasakyan nila kaya mabagal, lalo na kung city driving... bilang lang ang matinong kalsada. I don't think dahil nagtitipid ng gas.
And I also agree that A/Ts, due to its design, has a more sluggish response during acceleration compared to a M/T car. The reason being that fluid coupling is initially used inside the torque converter up to a certain speed before the lock-up clutch is engaged. In contrast, during acceleration, M/Ts only uses a fraction of a second of clutch slippage before it can be fully engaged. Hence, the seemingly more peppy, burn-out-inducing response when driving an M/T.
At any rate, graduate na ako sa M/T... it's a "been there, done that" sort of deal. Now, it's my turn to take it easy and I definitely enjoy the more laid-back ride on an A/T. I should've done this a long time ago. Pansin ko din pati mga passengers, hindi uga ng uga mga ulo nila pag A/T dahil suave ang acceleration at engine braking. Pwede mag timpla ng juice habang tumatakbo.
Though, banned ang pagkain sa loob ng sasakyan ko... ma-asawa o anak. :D Hiwalay kung hiwalay! j/k lolLast edited by oj88; January 7th, 2010 at 06:38 PM.
Kung walang spare tire, invest on a Inflator kaysa sa sealant. Inflate the flat tire +10 psi than...
Liquid tire sealant
