Results 11 to 20 of 96
- Sep 2008
- 737
January 8th, 2010 12:52 PM #12
Na the Innova while is the spiritual descendant of the Tamaraw FX is not the real descendant the Avanza is the real descendant of the Tamaraw FX. THe Innova has become an MPV family vehicle while the Avanza is still an AUV. And yes being used as a taxi nagmana sa lolo (Tamaraw FX) at tatay (Tamaraw FX Revo) nya...
January 8th, 2010 01:23 PM #13
well if the ts could afford the 3thousand difference, needs space most of the time, dosent really care kung global or 3rd-world car.. and prefer to drive high, not ing the line of "headlights of taller vehicles...then avanza ang best choice...
January 8th, 2010 01:36 PM #14
Yes, typically
- steering radius is bigger;
- better handling in dry conditions...the Vios is designed to understeer...
- better braking
an FF car would:
- provide bigger interior space...this was one of the advantages of the MB100, as it was front-drive...
- better FC because of fewer components, which mean lower weight
- cheaper maintenance
In terms of economy, the Avanza isn't bad, but the Vios is terrific. Have yet to formally test the 1.3 versions of either car, though.
Any collision strong enough to actually reach the drivetrain of a FWD car will have to go through the radiator, engine and auxiliaries first... so it's not that big a deal. Note... there's a reason that front-wheel drive vehicles have CV Joints... it's so that movements of the front wheels won't rip the transmission apart. Accidents that affect one wheel and that even destroy suspension parts won't wreck a FWD drivetrain (from experience). At worst, you'll need to replace the CV Joint and an axle. In most cases, just the CV Joint. Sometimes, nothing at all.
http://www.familycar.com/nextcar/step3.htm
Rear wheel drive cars have their weight distributed closer to 50/50 between the front and rear wheels, which is conducive to a smoother, more stable ride. Because of the weight distribution, the rear tires and springs can take on their fair share of the work load so the car can have higher cornering limits and greater maximum stopping power.Though yes, the base 1-series is more agile than the Focus... but at the top of the range, Focus RS versus 135i? The RS is actually faster.
If you need to pull a heavy trailer, you should also be aware that rear wheel drive allows for a greater towing capacity than front wheel drive.
http://lifestyleeurope.wordpress.com/2009/10/05/the-caravan-club-awards-mazda6-estate-category-win-at-towcar-of-the-year-2010/
Mazda6: Rated at 1400 kg towing capacity.
Unless you're towing a 4000 kg trailer with a duelie pickup, this is not a consideration.
And note: the Avanza's rated towing capacity is just 500 kg. In this comparison, both car's towing capacities are limited by their engine size.Last edited by niky; January 8th, 2010 at 01:49 PM.
January 8th, 2010 02:29 PM #15
In a minor or medium force collision that resulted to joint damage, here we can see how expensive replacing an outer CV joint or worst axle (not a boot ha?) than with the most common McPherson strut type of the RWD Avanzas.
January 8th, 2010 06:27 PM #16
dati ganyan din ang dilemma namin. we went to picking the Vios J. better interior and ride.
Certified MB Addict
- Apr 2007
- 2,284
January 8th, 2010 11:14 PM #17Depende yan sa purpose mo sa sasakyan, if its for transporting people only then the Vios would suffice, but if it will be used for hauling people AND cargoes at the same time then the Avanza would be the prudent choice. Being the fleet manager in our company, nagkaroon din kami ng discussion with the higher ups when the Avanza came out as to what car would be the better choice for the sales people in our company, we eventually agreed that the Avanza was the better choice since it can also double as a delivery vehicle for clients that would order small quantities but need our products in a hurry. So far we have 5 Gen 1 Vioses and 6 Avanzas (white). We intend to eventually replace our service vehicles into Avanzas in the future as we gradually dispose of older cars in the fleet like the big body and the lovelife Corollas.
January 9th, 2010 11:27 AM #18
By the time you have a collision strong enough to damage the CV joints, your engine (Avanza or Vios) will be affected, the manifolds will be wrecked, the radiator destroyed, the aircon compressor on the Vios destroyed... alll engine accessories on the Avanza (since they're all at the front of the engine... the Vios's alternator is in the back)... Basically, you're looking at a 50,000-100,000 peso job at the casa, whichever among the two you're driving.... if you have a frontal collision that is sufficient to dent a drive axle... the entire front end of the car will be utterly destroyed...
Other than extreme cases like that, CV joints are part of normal maintenance. In a rear-wheel drive car with an independent rear suspension instead of a live-axle, you'll have the same issue.
The Avanza is only better in this regard because it has a live-axle, not because it's RWD. And that live axle is part of what limits ride comfort on the Avanza compared to the Vios. While the Vios has a rear torsion beam, the lighter weight of that versus a live-axle makes it easier to tune for ride comfort.
January 11th, 2010 02:13 PM #19
Come on people... if the sole consideration you have is the cost of repair if and when you hit your front wheel against an immovable object...
In my many many years of driving, I have yet to damage a car in that way.
I find the collision repair bill consideration very pointless.
January 11th, 2010 03:42 PM #20
The K3-VE engine of the 1.3 Avanza was intoduced in Japan around 2000 and 2001. This was the Toyota Sparky.
You can almost see the similarities between the sparky and the avanza.
http://specs.amayama.com/toyota/sparky/2002_6/
Rebadged to Daihatsu Atrai:
I agree. travelling by train is always the fastest way to travel. kami din dati sa Bangkok, we...
Makati Subway. Completion date: 2025
