Results 51 to 60 of 64
- Apr 2008
- 188
December 14th, 2008 01:53 AM #51*yapoy
yes gumagamit ako ng AUX, pero d ako nagchacharge sa car.
actually napansin ko yung sound nung nasa nlex ako na parang sumasabay sa apak ng accelerator. so nag observe ako kase baka sa belt lang. pero wala ako nakita sa engine so nung nagstart ulit ako and nag power ng stereo dun ko na narinig ulit yung whistle sound.
about head unit yeas pioneer 2050 po, may amp naman po ako na gamit sir. dinig ko yung static sound sa separates
- Apr 2008
- 188
December 16th, 2008 09:42 AM #52ok na static i bought this anti-static, nawala na yung huni... ano ba usual cause nyan?!
isa pa tanong...
papano ba mag balance ng sound using yung cross-over na nasa amplifier? i mean paano ang adjustment... lets say sa sub.. yung sub ba dapat as in Bass lang lumalabas at wala kahit voice? then sa midbass ng seps parang masyado kse malakas ang bass na pag nilalakasan ko na eh malakas din yung vibration na pinto.. sensya na matanong masyado... inaaral ko pa po kase ang about car audio settings...
December 16th, 2008 04:49 PM #53
Sir ano amp mo ilang channel? are you using 2 amp system?
Medyo delicado kung mali ang set points ng frequency cutoff mo sa each speaker then you play it loud. But I assume naka passive setup ka meaning you use the crossover nung separates then you are safe.
Just basic understanding sir, say tweeter it can handle only high frequency signals 3.5Khz up.
Mids depends on the speaker brand but usually can handle 60Hz to 4Khz
Sub can handle as low as 30Hz to 63Hz to some they over lap it to 80Hz.
First step in tuning sir ay level matching I hope na level match na yang system mo.
- Apr 2008
- 188
December 16th, 2008 06:46 PM #55
Here is a good read about level matching ...
http://www.kotseaudioclub.com/forum/...p?f=19&t=19796
if you find it complicated go to a reputable car audio shop they can level match your system and tune it for you. With a fee
but masarap mag DIY if you know the basics and if you are lost on the process, stop and seek help again.
Enjoy
- Apr 2008
- 188
December 17th, 2008 06:59 AM #56
- Apr 2008
- 188
December 20th, 2008 08:30 AM #57ako ulit...
question... sa sub ko may lumalabas na sound ng voice... ok lang ba yun or kailangan purely Bass lang ang lalabas dun?
December 20th, 2008 09:55 AM #58
dapat wala voice na lalabas dyan
, ano cutoff mo sa LPF sa sub mo? dapat hangang 60-63hz lang.
- Apr 2008
- 188
December 20th, 2008 04:46 PM #60hirap ah trial and error ito ah... ok lang enjoy naman... pinakinggan ko kase from the inside eh ok na yung tunog.. kaso kahapon nung naopen ako ng trunk dun ko napansin na may voice pala, mahina lang naman.. kaya consult agad ako... paano ba adjstment nito...and ano ang consequence it hinayaan ko lang na may voice na lumalabas?... will it damage my sub? im really interested to learn more about the craft of car audio set up...
Though not on a people carrier like the Innova, I have Yokohama es32 equipped on my Sylphy since...
Finding the Best Tire for You
