Results 21 to 30 of 64
- Nov 2008
- 32
November 19th, 2008 12:04 PM #21sir, ano po maganda na seps? are my choice for infinity seps good for SQ and what about amp for the Seps, ano po maganda, salamat po..
November 19th, 2008 01:01 PM #22
iilan pa lang na audi ko na seps. ngayon gamit ko is hertz dsk, ok na ok naman siya. audi ka muna ng mga seps para mahanap mo gusto mo. pero kung walang chance ok na din siguro yang infinity. as for the amp ok na jbl. mura na lang din mga jbl budget wise.
- Apr 2008
- 188
November 19th, 2008 02:25 PM #23ano marerecommend nyo kung sa 6" front seps lang and 1pc sub na 12"? and ilan watts kaya... plus do i need cross-over and capacitor?
- Nov 2008
- 123
November 19th, 2008 06:25 PM #24Yup I agree with you ..with separates yes but what if you have a coaxial..but Im talking to a day to day drive not relying on those fancy pink noise meters if you compete with SQ yes imaging must be on the front and ..just put the fader full to the front..but if you are listening to a day to day music and driving correct me if Im wrong Im sure it is different on what you hear if you have a rear speakers...If you have a rear speakers on your car try it so that would hear the difference...it works for me I can hear my music not coming from the back but somewhere in the middle of my car..it sounds relaxing..And if your a SPL person you need massive subwoofers, huge box and tune your box really LOW..and compromise the SQ..But anyways...this is just my opinion..I respect you..everyone is different it all depends on the person who listen...
November 19th, 2008 07:06 PM #25
np. anyone is entitled to their own opinion and has its own listening preferences. as what I say, that is if his looking for SQ then he should not bother about the rear.
Actually I used to have rear fills, ayoko lang talaga nung staging ko with rears kaya ko tinanggal. problem ko naman without the rears is parang kulang ako ng mids. yung rear fill ko kasi walang filter kaya may kick pa rin yung bass. yun nga lang basag na at higher volumes.
audi na lang muna ng mga setup para makuha yung desired sound, then decide from there.
- Nov 2008
- 32
November 19th, 2008 07:30 PM #26Ok sir Flakez maraming salamat, id probably go with a good seps first with amps, thenbka cguro po maglagay din ako ng rear fills powered by the HU, den pag may budget na uli, subs and amp naman, and id go Infinity all the way. thanks sir...,
November 19th, 2008 07:50 PM #27
- Apr 2006
- 9
November 19th, 2008 08:40 PM #28Well to start with 15K budget. I would rather buy front components close to your budget. Second do you really want to add rear speakers? I you buy a decent front components it will perform & sound better than 2 cheap speakers. You will have a better soundstage overall. Then you can step next on the second upgrade (amp?). This is just my opinion, goodluck to your install. PM me anytime.
- Apr 2008
- 188
November 20th, 2008 12:06 PM #29pwede ba ganito... ill get a good front seps then a sub then yung stock na front ko itransfer ko sa rear kung kasya...
- Apr 2006
- 9
November 20th, 2008 11:57 PM #30Look at his way my friend. stock is stock. If your gonna acquire a superior front speakers. you want to hear every note & detail that will come of that of that speaker without any disturbance blending in. (stock speaker)
I will give an example. I am using a B&W 603 for my hi fi at home. think of it that my house is your car
The reason I am not adding any stock or cheap speakers.
1. They cannot blend with the soundstage. they will just interefere.
2. They will distort at high volumes. we dont want to hear distortion.
3. Lastly if you want to add speakers for your rear. it has to be the same caliber as your fronts (rearfill).
Hope this help? Goodluck!
Engines also work harder, right?
