Results 1 to 10 of 64
- Apr 2008
- 188
October 27th, 2008 06:19 PM #1Hi,
Newbie here.. hope someone can help me and give me advice regarding my audio upgrade for my nissan GX.
i currently have the stock audio. the problem is yung speakers ko sa front doors lang, kailangan ko ba talaga butasan yung sa likod ko para makapag mount ng rear speakers or my other option pa?! My budget is 15k max., may mabubuo kaya ako? gusto ko lang kahit not too much boom boom..
October 27th, 2008 08:40 PM #2
not necessarily sir, basically sir i think is ikaw ang main na makikinig from your music. So, front stage lang ok na po, kahit wala na rear fill. Para rin mo ma stretched natin gagamitin na budget. Sir iyung budget ninyo including head unit pa po or exluding na HU? meron din pong mabubuo na system. Depende na rin po kasi kung ano gusto ninyo, either SQ or SPL or tamang Loud & Clear.
I think may thread na rin po tayo regarding ICE. try ninyo po search.
October 27th, 2008 09:27 PM #3
hmmm... sa low budget, meron po sir... targa all the way with v12 amp ok na.
as xer said, you dont need the rear for the setup... ok na yung front na lang.
setup:
targa seps mga 6" ok na
10" or 12" targa subs (sealed)
v12 300 watts rms ok na
2050 or 3050 pioneer na HU
sa gantong setup mukang kaya sa 15k budget sir.
- Apr 2008
- 188
October 28th, 2008 09:02 AM #4thanks mga sir,
so hindi ko na pala need magbutas sa likod for the rears... ayaw ko din kase butasan eh...
for the subs does it include yung box na? or may nabibili ba na included na ang box for a particular speakers?
- Apr 2008
- 188
October 28th, 2008 11:09 AM #5...nga pala saan maganda bumili, and kung ipapainstall ko mga how much aabutin?
October 29th, 2008 10:27 PM #6
kasama na po sa setup yung box, for the shops naman:
jeff tan araneta ave
c3 audio banawe, yung tapat ng dencios
- Apr 2008
- 188
- Oct 2008
- 4
October 31st, 2008 01:30 PM #8kuya tanong ko lang po kung saan makakabili ng magandang sound system yung buo na, yung ikakabit nalang
October 31st, 2008 01:38 PM #9
- Sep 2008
- 33
November 6th, 2008 03:01 PM #10Here's my take on a P15k budget:
Replace the stock speakers-- 100% improvement agad! You'll need separates for the front and co-axial for the rear deck. Since its a Nissan, you'll need 6.5 inch round speakers (front and rear). I don't think you'll need to put a hole in the rear deck. May naka-abang na yan. Baka dun lang sa cover.
Blaupunkt, Boston Acoustics, Pioneer, & Alpine co-axials range from P2.5k to P3.5k while separates starts at around P4.5 to P7k. High-end speakers starts at P7k.
Make sure you get the best speakers you can afford for the front. Audio imaging is always best if its coming from the front of the car. The rear deck is for ambiance only. Best for front is separates (nakahiwalay yung tweeter sa woofer). Mount the woofer at the door and the tweeter a little bit higher. This provides separation of mids and highs while making the lows nondescript.
You can stop at this point. Pakiramdaman mo muna, the amps, subs etc. are optional. Remember, may break-in period ang speakers. They will reach their peak performance after about a week.
You can get a decent amplifier for P3.5k. V12 brand is ok, medyo malaki lang sya. Pwede wala muna amp kung happy ka na sa tunog ng speakers mo.
Then add some bass, subwoofers starts at P3.5k, boxed and ported na sya.
If you opt not to have an amplifier, you can get powered subwoofers that starts at P3k. There's also low profile subs that can fit under the seat, I saw an NBN brand model that sells for P3.5k. Ok naman ang tunog.
You can leave the HU alone, unless may feature ka na hanap e.g. iPod control, aux plug. HU starts at P5k, decent na yun makukuha mo, mid-range Pioneer or low end Alpine.
Good luck.
BTW, ingat kung sa Banawe ka pupunta. Deal with shops ... wag ka manghinayang sa konting deperensiya sa presyo. Just my 2 cents worth.
