Page 276 of 392 FirstFirst ... 176226266272273274275276277278279280286326376 ... LastLast
Results 5,501 to 5,520 of 7833
    Jun 2005
    #5501
    ^ ako. Ayos naman sya. Wala ka nga lang lube. Meron tinda 5pcs worth 700plus lang sa lazada.
    #5502
    Quote Originally Posted by sirkosero View Post
    Na try nyo rin po ba yung mothers claybar? How does it compare with the cheaper 3m? (When maybe a nanosliq for a lubricant is used with the 3m clay).
    What do you recommend for micro scratches and swirl marks? Andami na kasi sa oto ko and i'm beginning to doubt na kaya ko i diy. Im thinking kailangan na i paintshop para ma rubbing compound and buff. If tama yan, how to judge whether the paint shop, their staff and their equipment are competent? Tia
    #5503
    Sir for my new car MUX
    What are the basic things to buy for
    A. Maintenance of its paint (pearl white)
    B. Mapakintab/neat/presentable/awesome
    C. Remove water marks windows and grills
    D. What pede pagawa sa carwash at hindi. Minsan kasi di ko alam if salestalk n lng or sometimes sila pa nakaka create ng gasgas :/
    E. I read chamois is not good so whats the best alternative?
    Tried to read some of the posts here medyo malalim sir di ko ma absorb.
    Btw price is a consideration po if possible within the average budget thanks
    Aug 2012
    #5504
    I prefer using clay pad than traditional clay bar. Mas sulit ang clay pad dahil washable and reusable up to sawa. I used clay bar before and 1-2 use lang, tapon na.
    Sent from my D5833 using Tapatalk
    Jul 2015
    #5505
    A. Maintenance of its paint (pearl white)- Regular and proper carwash, (2 bucket method)
    B. Mapakintab/neat/presentable/awesome - pag wala swirls and no fading, lagi yan makintab, but to add a bit more of shine, a synthetic wax or sealant will help, if you have budget, glass coating will give more glass like look, since light colored vehicle nyo.
    C. Remove water marks windows and grills- acid mark remover, non acid ay spotless from carpro and wurth.
    D. What pede pagawa sa carwash at hindi. Minsan kasi di ko alam if salestalk n lng or sometimes sila pa nakaka create ng gasgas :/- always ask then to use a separate wash mitt sa taas at baba ng car, and rinse regularly per panel.
    E. I read chamois is not good so whats the best alternative? - best alternative ay waffle weave towels.
    Hope this helps.
    Sent from my iPhone using Tapatalk[/QUOTE]
    #5506
    Quote Originally Posted by Kitoy22 View Post
    Hope this helps.
    [/QUOTE]
    Wow thanks sir. The products you mentioned, is it readily available in malls and other car care dealer? Tnx
    Mar 2016
    #5507
    Mga sir pano.matnggal acid rain?at pano maiwasan yn? Any experience po sa ngpapacarwash yun along Monty DBA kasi ngcarwash po.salamat
    Sent from my Lenovo A536 using Tapatalk
    Quote Originally Posted by Mcqueen dylan View Post
    To prevent acid rain on paint we park cars in a covered garage. Joke
    we use wax/sealant/hard coats.
    To remove... use a water spot remover from meguairs. There are other ways but that might damage the clear coat/ paint.
    Always follow instructions on the label.
    #5509
    How often do you clay?
    I feel like crying now!!! I didn't get to wash my car for 2 weeks (it had 2 layers of blacklight and V-07), now it feels a little grainy. There was a thin film of dust for 2 weeks kasi. I did not think it would affect the paint. It was in covered parking and the only time naarawan was on my short drive going to work. It looks like I have to clay this again. Kaka buff lang ng casa last December
    Time to step up to an acrylic based sealant ie cg jetseal or their new c9 product.
    Blacklight and v7 are nice but as you described they absorb(melt?) impurities hence the rough surface. The hard sealants/coats would prevent that.
    Apr 2012
    #5511
    tamang OC ka mam C, 2 weeks pa lang yan i think no need to clay muna, light wash lang yan then konting spray ng V07, makintab pa yan sa 2 layers mo ng blacklight...
    ako, i clay na lang now kapag plano ko mag-polish
    Mar 2016
    #5512
    Ok.sir salamat sa info...any suggestions pa po? AU's LNG po ba magpacrwash sa labas ? Any idea sir auto detailing
    #5513
    A few months ago I did 1 layer of KAIO and 4 layers of KSG ( at least 24 hrs apart)
    What is it with Metro Manila?!?! I just skipped a weekend of waxing and this is what I get :rant: My car's paint was so glossy madudulas langaw and now this :rant:
    Mother's clay bar kit okay na ba?
    Nanoskin prep sponge...its reuseable unlike typical claybars that only last a few uses.
    Read this
    Carnauba Wax Melting Point: How hot is Too Hot?
    Jul 2015
    #5515
    Wow thanks sir. The products you mentioned, is it readily available in malls and other car care dealer? Tnx[/QUOTE]
    Yes sir, most of them can be found in local stores, but the better brands are found somewhere else. Online resellers, specialty shops.
    #5516
    I washed and did 1 layer of blacklight. I knew something was wrong kasi hindi na nag slide yung towel when I was drying akala ko makukuha sa blacklight, hindi na e.
    Jul 2015
    #5517
    Hi Ms. C, try rewashing it again, usually if dirt is baked under the sun ng matagal, medyo nadikit sa paint.
    IMHO Blacklight and V7 does not protect very well, has poor water beading and sheeting, although they look very good, specially in dark colored cars. We usually use these products pag na sali kami ng car shows.
    Mas ok pa jetseal nila in terms of protection.
    If kaka buff palang, like what others suggested, a mild prep sponge will do to remove the ingranied dirt sa paint. or KAIO, para non-abrasive parin.
    #5518
    I have KAIO. Do I have to do this ASAP? If I wait one more week kakapit pa ba lalo yung dirt?
    Cat
    A second wash and this time try to soak and rinse then wash.. like in the video. Is this how you wash your car?
    How To Wash A 4x4 Truck - Chemical Guys Glossworkz Gloss Booster And Paint Cleanser - YouTube
    Also did a two wash a few hours ago. Extra clean mitts necessary
    1. Bug&tar heavy duty soak&wash
    2. Megs uww for a light wash. Rinsing already shows good beading
    3. Extra gloss with autglym rapid detailer.
    #5520
    Cat
    Yup but I don't have a foamer. Mukhang mapapa car was ako ng gabi na
"Tamang OC lang" - a newbie's guide to car appearance maintenance
