This will depend sa LSP na gamit mo, sa white and silver or other light colored vehicles, what we want is something that will look like a coat of glass or candy like shine or nail polish. And usually this will come from sythetic sealants. Klasse twins is noteable for that candy coat like shine, which you are using right now.
Pero these sealants will just add about 5-10% lng ng shine. Most of it will come from the paint itself, on how smooth the paint surface is.
Thanks! Di ako maalam sa electrical stuff, pero sa mga nababasa ko dapat yata step-down transformer ang gamitin para sa mga power tools
Thanks. Smooth naman ang surface nya after ko ma-clay. Siguro pag na machine polish baka mas gumanda, pansin ko importante din may magandang lighting condition when applying KSG, pag di mo tinignan ng maayos may mga spots na medyo hazy at mahirap tanggalin, pati ang hirap magpahid na sobrang nipis, laging yung first wipe ko makapal![]()
Need more experience pa
Curious lang, Kitoy22 is a professional detailer?
What I mean smooth is wala paint defect, like in the picture below.
Karaniwang hindi sya kapansin pansin, lalo na yung swirls and holograms, specially sa light colored vehicles. nakikita lang sya under strong light. Pag my ganito yung paint, medyo nagiging dull yung paint or hindi crisp yung reflection.
For easier application ng ksg, lagay mo ksg sa atomizer, kuha ka ng tabo ng tubig, gamitin mo ay yung flat cotton oang make up, dip sa tabo ng tubig, pigain, dapat hindi drpping wet yung cotton. Spray ksg sa piant surface, wipe with damp cotton evenly sa paint surface, criss cross pattern, then wipe off pgkatapos.ma avoid ang msyado mkpal ang lagay.
Prof detailer? It depends how you define it. Hehe
Thanks! Ganito ginagawa ko, pero yung applicator na gamit ko yung foam pad na nabili ko sa Ace na kulay yellow.
Professional in a way na you're making money from it and doing it in a professional manner. You do however seem like you're an expert about detailing
Grabe yung nabasa ko sa AG, $275 charge tapos ang sagwa ng gawa
Yung foam pad is ok naman, my tendency lang sya to absorb the sealant, kaya you may use up more of the sealant. But as long as it works, and your happy with the results, mas importante yun.
Thank you for your kind words sir, if that is the case, I may be a professional but maybe not an expert. I Still need a lot of things to learn and experience.
Meron din dto satin nya, madami hack jobs, pag mgpa detail ka sa kanila, automatic na kukunin ay yung rotary with a wool pad without even assessing or trying out less agressive approach.
And if you need any help with your GG polisher, i'll be more than happy to help you. Its a durable polisher with lots of power , hanggang ngayon buhay pa yung sakin, palit palit lang hg carbon brush, still doing its job really well..
I actually need help sir, as of now, out for delivery to freight forwarder, sana may magreceive at mapaforward ko na dito sa pinas. Ano po gamit nyo na transformer for your GG? Nakita ko kase sa spec sheet 120v sya, puro 110v ang nakikita kong AVR sa Ace nung nagtingin ako, I'm assuming na pwede naman gamitin yung 110v, pero dapat yata step-down transformer ang gamitin and not AVR, or are they the same?![]()
120V lang sir? Walang range na 110v- 120v?
Mas ok sir yung Step down transformer instead of AVR since heavy duty na tools ang gagamitin, and consider the wattage of the machine, if GG is 800 watts, yung step down transformer should be 2-3 times more, so atleast 1600 watts just to be safe.
I forgot the brand nung gamit ko, sa Raon ko nabili, ka edad nya yung polisher ko buhay pa naman, saksakan lang naluwag.
Ngayon he is serving 2 polishers, with out any issue. Post ko dito yung brand pag balik ko sa shop.
Wala pa kase dito yung item kaya hinde ko pa nakikita, pero nag search ako ng spec sheet ang nakalagay 120v, tapos ang lumalabas sa mga Google search ko is ang 110v daw is old standard tapos 120v na nga ang standard ngayon, ang iniisip ko lang wala akong makitang label na 120v na outlet, baka 110v lang nilalagay nila even though you can plug in a 120v appliance in them, sana ganun nga.
Bro 120v dib polisher ko and I use 110v AVR kasi low wattage ang polisher. It will be fine naman according to my research.. Basta within +10/-10%.
From what I read, pag ganyan kataas na ang watts mas maganda nga ata step down transformer lang. Use atleast x2-x3 ng watts ng machine.
Anyone interested in buying my megs m205? Ung pinakamaliit 1600 nalang. 2 pea sized lang nagamit
