Page 141 of 392 FirstFirst ... 4191131137138139140141142143144145151191241 ... LastLast
Results 2,801 to 2,820 of 7833
    Aug 2012
    #2801
    Quote Originally Posted by crosswind View Post
    Thanks for the reply
    How do you use it?
    Just spray Quick Detailer on the surface to be clayed. Then slide the clay bar across the surface repeatedly until it feels as smooth as glass. The surface should always be lubricated during claying. If you don't have QD, you can mix water and car shampoo in a spray bottle, and use that as lubricant. You can clay painted surfaces and also glass. There are good videos from Meguiar's and Chemical Guys that you can find in YouTube.
    For water etching (in surface), you need to use liquid polish. Only water mineral deposits (on surface) can be removed by claying.
    Aug 2012
    #2802
    Quote Originally Posted by paos View Post
    Ok lang kada wax gamitin ang buffing nachine?
    If you are referring to single-speed orbital buffers, then they are really intended for waxing so you can use it every time you wax the car. Usually may kasama yang 2 or 3 bonnets.
    Foam bonnet > for applying wax or polish
    Micro-fiber bonnet > for buffing
    Single-speed buffers are not intended for paint correction. You need variable-speed Dual-Action Polisher for this task. But for waxing, they will get the job done.
    Jan 2014
    #2803
    Quote Originally Posted by red_one View Post
    I don't get the last paragraph
    Aug 2012
    #2804
    ^For water etching (in surface), you need to use liquid polish. Considered scratch na kasi yan. You cannot remove scratch by clay bar.
    Water spots (on surface), can be removed by claying. Usually these are mineral deposits left above the surface after water drops had evaporated.
    Jan 2014
    #2805
    Thank you
    really appreciate especially the tips
    Nov 2014
    #2806
    Tnx for the info red one...
    Nov 2014
    #2807
    Balak ko kc bumili ng buffing machine. Tnx ulit
    #2808
    Hello po mga sir tanong ko lang kung meron bang advantages ang synthetic wax over Carnuba wax or is it just a matter of preference?
    Jan 2014
    #2809
    Quote Originally Posted by elaz View Post
    Carnauba wax produces deep,shine and gloss while
    synthetic wax can last for 2yrs and
    water beading is seen that will last for a long time
    #2810
    I did some search and oftenly they refer synthetic wax as sealant. Is wax and sealant the same thing? Im now using 3m synthetic wax and im happy with the result. Some suggest to use carnuba wax on top of synthetic wax. Isnt it overkill na?
    Btw how can i achieve water sheeting? Which product/brand should i use?
    Thanks sa reply ☺
    Jan 2014
    #2811
    Sir red_one I need an opinion
    First pic my car's paint surface
    2nd from the Internet, do you think it's etching from birdbdropping and needs repainting?
    Nov 2014
    #2812
    Fwfssvdbdvrbrbfbfbfb
    #2813
    correct me if im wrong pero ive read from somewhere na hindi daw advisable na car shampoo ang gamitin as clay lubricant as this will degrade the clay fast. May nakapag try na po ba ng Nanosliq diluted with water? ( 1:1)
    Sep 2011
    #2814
    Quote Originally Posted by ez3kiel View Post
    Nung bago pa lang ako ginamitan ko ng joy. nagccrumble yun clay at tumitigas. Kala ko kasi ok lang kasi purpose ko naman alisin yun old wax. Kaya mula noon tubig lang gamit ko. Running water sa hose.
    May 2011
    #2815
    Hi am new here the guide from page 1 and the pdf file is vey helpful thanks for the guide. Been using microtex product for a quite some time. Pero kakabili ko lng un mga micro fiber products nila kht mahal pero I do hope it will last long pra sulit bili ko haha
    Jan 2014
    #2816
    can someone give me an opinion regarding my question?
    TIA
    Jan 2009
    #2817
    TIA
    Tingin ko sir repaint na. Ask ka na rin sa detailer o painter 😊.
    Jan 2014
    #2818
    Quote Originally Posted by smuiv View Post
    Tingin ko sir repaint na. Ask ka na rin sa detailer o painter ��.
    http://tsikot.com/forums/attachments...9149645277-jpg
    ito po yung pic incase hindo mo pa nakita
    thanks bro
    Jan 2014
    #2819
    double post
    Aug 2010
    #2820
    As long as it's car shampoo and clear-coat safe, it won't degrade the clay. Hell, a lot of people actually use running water as a lubricant. But it's too wasteful on the water so just use your car shampoo. You need to make sure your car has already been washed beforehand and then you wash, clay, and rinse it.
"Tamang OC lang" - a newbie's guide to car appearance maintenance
