Page 6 of 15 FirstFirst ... 2345678910 ... LastLast
Results 101 to 120 of 287
    Quote Originally Posted by brushless View Post
    Mine looked exactly like this with crack stress all over:
    The one connected to the upper hose was the first to give in as the Mechanic replaced the hose and it broke like skyflakes. Lol! They gave me samples of the fragments and it simply pulverized when I lightly squeeze it with my fingers. I guess I was lucky to have prevented a catastrophic failure! Otherwise, I could have spent more for a tow truck and a have very bad bad day.
    I guess, this is really what happens when you say your radiator cracked. More money for me as I learn more!
    how old was the car? is this a toyota?
    Dec 2017
    #102
    ^That's not mine. It's just an image from the net.
    Mar 2004
    #103
    Old vehicles with brittle plastics were in part caused by the desire of many companies to use environmentally friendly parts during production ... started around 1990s ...
    #104
    radiators are plastic now, mainly because they are cheaper to manufacture than metal radiators.
    everything else is a bonus.
    Apr 2018
    #105
    Ganto dn yung problem ng car ko,
    HONDA JAZZ 2005, AT
    LUMALABAS UNG H KAPAG TIRIK UNG ARAW NETO MEDYO LUMALA, 18KM PA LNG LUMABAS N SHA,
    BALAK N NMIN PALITAN UNG RADIATOR,
    ANY TIP AUTO PART LOCATION, CALAMBA LAGUNA AREA AKO,
    SKA ANU GOOD N REPLACEMENT NG RADIATOR PARA SA TSIKOT KO,
    MARAMING SALAMAT SA REPLY, BIG HELP
    THANKS AGAIN.
    #106
    Quote Originally Posted by neoson9999 View Post
    First of all, I apologize for hijacking this thread. I would create my own thread but Tsikot forum's anti-spam measure prevents me from doing so.
    Bale meron po akong 1997 na Honda Civic. Nung nakuha ko po siya, naka rekta yung fan niya tapos wala siyang thermostat. May mga nabasa ako dito sa Tsikot forum at sa mga FB Car groups na hindi daw okay yung ganung setup kaya naisipan ko siya ipabalik sa normal. Kaya bumili ako ng original honda thermostat at thermoswitch.
    Fast forward sa naikabit na yung thermostat and thermoswitch. Dun na lumabas ang problema. Nag ooverheat na yung kotse. Pina overhaul ko yung radiator ko kaso parang walang nagbago, overheat pa rin.
    Kanina, tinanggal na lang nung mekaniko yung thermostat at binalik sa rekta yung fan. Ayun, di na nag overheat.
    Sinisisi niya yung thermostat. Pagkauwi ko, pinakuluan ko agad yung thermostat at bumuka naman siya 100% so malamang hindi yun ang prob?
    Btw, additional detail lang, pansin ko pala pag andun na siya sa point na nag ooverheat siya, napupuno ng mainit na tubig yung reservoir.
    Any ideas or suggestions po kung ano kaya ang problema at kung ano pwede ko gawin? Water pump kaya or radiator cap? Di kaya baliktad lang pagkakakabit nung mekaniko sa thermostat?
    Try replacing the rad cap
    #107
    Quote Originally Posted by istan View Post
    Assuming ur radiator has no micro cracks that lets out steam.
    Water in radiator is usually between 98c-103c, and to prevent boiling of water to steam, it is placed under pressure. The Radiator cap regulates that pressure, excess pressure, ie:creation of steam will spill water to the reserve.
    If your cap fails, its will not seal properly and suck in air, same with micro cracks. Now if air passes thru the engine, it will overheat. Thermal runaway, not enough coolant.
    Jan 2008
    #108
    I think radiator tanks are made of plastic is because cores and tubes are made from aluminum.. unlike radiators before that are made out of brass.
    Apr 2018
    #109
    Sir, it can be repair or Disposable na?
    #110
    Quote Originally Posted by epr View Post
    aluminum leaks can be fixed.
    it needs special equipment and skill/training, but it can be fixed.
    Apr 2018
    #111
    Thanks Doc
    Jun 2008
    #112
    Isuzu Dmax LS 4x2 Manual 2011 LS
    1. napalitan na compressor at radiator Kapag mainit at tirik ang araw nawawala ang lamig.. Kapag tumakbo naman lumalamig pero parang hilaw.. Yung tipong lumalamig naman pero parang delayed andar ng compressor para magpalamig kasi parang mararamdaman mo munang parang walang lamig tapos lalamig ulit.. Ano kaya problema mga sir? Walang Auxiliary Fan
    2. Napansin ko lang yung temperature gauge nya mas mababa sa kalahati (possible thermostat problem kaya ito?)
    Isuzu Alterra 2008 AT 4x4
    1. May twice na nangyari na kapag naka-idle tumaas yung temperature gauge between half and 3/4 - AC On at 2pm.. Auxiliary Fan working at mabilis ang ikot.. Ano kaya possible cause?
    2. Long Drive then Uphill (AC On at 2pm) - Napansin ko umakyat ulit sa between Half and 3/4 and Temperature Gauge. Rev ko kasi engine til 3k RPM.. Pero nung bumaba sa 2krpm to 2.5k RPM lang eh bumaba naman ang Temperature Gauge.. Location was in BOKOD, Benguet from Nueva Vizcaya going Baguio.. Ano kaya possible problem nya mga sir? Dati naman kasi hindi umaakyat temp.. Steady lang sa Half..
    Parehong ang situations sa 1 and 2 nasa pagitan ng 10am to 1pm so tirik ang araw..
    Salamat sa mga magiging advice at mga opinions nyo mga Sir..
    thermostat is very cheap. replace na
    FOCUS
    Mar 2004
    #114
    Have your engine cooling system checked ... radiator fan, coolant, water pump, etc ... if the engine is too hot, the aircon won't function optimally ...
    #115
    vios 2006 (gen 1.5/1.3 L).
    mga bros, temp warning light came up.
    even when aux fan is running, i still get the temp warning in dash .
    no recent change in the system naman, except for brake pad change about 1.5k km ago and lugnut stud issue the other day.
    had it checked in jpwheels yesterday, was told that it was a bad fan, their comment was mahina daw. then went to exalta banawe, they said fan looks OK, as well as the water pump and no leak in system (cap also OK); since they could not identify the problem, they can only recommend to have the radiator checked and/or cleaned.
    then i realized, i can check the temp via obd scanner, so i did. from banawe to maybunga pasig, temp never went over 98c (prolly cause it was 5:30pm narin). will update my post later around 12nn.
    dati until about 98c (or 100c IIRC) ang inaabot ng coolant temp ko sa obd scanner reading via torque app.
    ngayon 90c or lowest * 88c nag blink na ang temp warning sa dashboard. issue just started yesterday. naka toyota long life coolant naman, was replaced just about less than 10k km.
    at first i thought it was a bad coolant sensor, but i can read naman via obd scanner that coolant temp is fine, so baka di naman sensor. any ideas kung ano pwede problem?
    btw AC works fine even when the temp warning came up.
    #116
    i had similar problem in my 97 sentra.
    after i had everything checked, the overheating was still there.
    finally, an old-timer advised me, to replace the aux fan. i said, "malakas naman ang hangin." the guy said, check it against a new fan motor".
    i did, and the difference was night and day.
    ever since i replaced the aux fans, the temp has been behaving.
    moral of the story: "looks ok does not always mean, it is ok".
    #117
    malakas daw hangin bro eh, sabi rin ni bro vinci, check the fan nga din.
    isa lang napansin ko kakaiba pala
    diba pag naka off ang engine, tapos mainit pa sya. kahit di mo start mag ON ang aux fan saglit. dito ngayon di nag ON, unless buksan ang AC (not 100% confirmed).
    Jan 2008
    #118
    Baka dual speed yang fan motor mo.. yung pang AC ay low then pag mainit mag on yung HIGH.
    #119
    pagbaklas kanina bro, 2 wire lang {+/-)
    update lang, sa banawe no mechanic wanted to replace the fan or motor. all of the mechanic there suggested to have the rad checked (ayaw talaga palitan yun aux fan). out of courtesy since i parked in front of toyocars (for an hour), i just bought a new thermostat (12 year old na yun installed)
    mang george did the radiator job albeit expensively (broke water inlet), bought one for me * 1.5k (later found out that it was only 950 php in toyocars orig). ok lang as long as maging ok sya. dropped by toyota to buy 4 liters of super long life coolant as he really wanted to use distilled water.
    btw yun water inlet had a small leak, and "crumbling" already parang paagnas na LOL
    going home, i noticed the temp light warning is still flashing red (intermittently) even when AC is On. and no more coolness felt in the cabin. longest drive home (kahit 1 hour lang), cause of the fear of overheating.
    at home, i checked under the hood wow parang hinipan ako ng heatwave! so i reversed the fans polarity and it worked normally na.
    BUT still getting the temp light warning even at 95c, dati naman at 98c di lumalabas ito [emoji848]
    #120
    may idea kayo magkano labor and water pump replacement?
    isa ito sa suggestions eh
    thanks !!
Radiator / Overheating Problem
