Results 61 to 70 of 85
September 18th, 2014 04:27 PM #61
I was able to use the car again in moderate to heavy traffic, 20 kms distance covered, in 1.5 hours. I just noticed that the temp needle is "higher than usual", probably 1-3 lines higher, with A/C turned on the whole time. Usual temp needle is at 2-3 lines below the mid line. but now on traffic, it reached the exact mid line. this doesn't happened before. it is just usually below the mid line even on heavy traffic. is this a sign of a clogged radiator as what JohnM mentioned before, or there's nothing to worry about as it's still within "normal" operating temp? car is 2002 Honda Civic VTi-S. Thanks!
September 18th, 2014 04:46 PM #62
High temp in traffic is most likely caused by a weak fan. Check your fans for unusual noises or alog. With the fans on feel the strength of the air coming out. Kung medyo mahina time to replace the motor na. Try to observe the temp din with the AC off in similar conditions. Kung bumaba most likely fan nga ang problem. Silipin mo na rin ang outside fins ng rad baka barado na. Number one kalaban dito balahibo ng aso o pusa
Coolant leaks could be another cause. Nasilip mo ba ang radiator and reservoir kung may laman pa after that incident?
September 18th, 2014 09:27 PM #63
Thanks again JohnM.. Yup, checked the radiator and reservoir, both are always full since the incident. I always check them before using the vehicle and no need to top up. Iniisip ko nga, baka barado like what you said. Sige, I'll check the fan motors na rin, but last time I checked, they are still quite strong. Kakalagay ko lang kasi ng Honda coolant kaya nag-hhesitate pa ako magpa-radiator cleaning. So far, yun palang naman na-notice ko. At least the car can now survive moderate to heavy traffic without overheating.
September 18th, 2014 11:22 PM #64
Add ko lang, tama JohnM, mas mababa ang temp with A/C off, kahit pa heavy traffic (tagaktak-pawis nga lang ako hehe). Ang hirap kasi i-measure yung strength ng fans by just feeling them with bare hands. Kung ako lang tatanungin na hindi expert at hindi laging nagccheck ng fan speed, hindi ko rin masasabi ang difference, unless significantly different na.
Anyway, thanks again JohnM. mukhang marami ka nang napagdaanan sa cooling system ng kotse mo ah hehe.
September 18th, 2014 11:26 PM #65
September 18th, 2014 11:46 PM #66
ask ko lang, ok ba mag top-up ng reservoir using distilled water kung pre-mix coolant ang nakalagay sa cooling system mo?
kasi nang nag-palit ako ng coolant last month kinulang na iyong honda type 2 coolant na nabili ko ( 1 galllon jug). eh napaka-hirap mag-hanap pa naman dito ng type 2 coolant sa atin so sa reservoir may halong distilled water na nailagay ko
September 19th, 2014 12:27 AM #67
September 19th, 2014 12:48 PM #68
September 19th, 2014 12:49 PM #69
September 19th, 2014 12:58 PM #70
Yes, i do think so. Since it's based on the 4th-gen delica/space gear, which in turn shares some of...
Mitsubishi Philippines
