Results 11 to 20 of 21
    Apr 2008
    baka iyong tensioner bearing ng drive belts niya? umiingay pag acceleration ?
    As per mechanic sir, ok naman daw since no noise naman when in neutral. May whine lang when accelerating. Hindi rin wheel bearing, no noise when coasting in neutral.
    Jan 2009
    Quote Originally Posted by tonyboy View Post
    Replaced the transmission fluid 3 weeks ago prior to replacing the release bearing and clutch disc.
    Prior to the oil change, walang whining noise whatsoever? If so, are you sure that the correct gear oil viscosity was used? Is the gear oil level correct?
    May 2009
    1st and 2nd gears share the same synchronizer hub/sleeve.....
    eto most likely ang may sira.....
    chipped teeth on the synchro hub, worn synchro,........
    bottomline, remove and disassemble the trans for better diagnosis.
    Apr 2008
    Update:
    Noise gone. Culprit was the Mainshaft Bearing. =)
    May 2009
    Update:
    ibig nyo po bang sabihin yung bearing ng input shaft? input shaft yung nakaconnect sa clutch disc
    or yung bearing ng mainshaft which is nasa rear part ng transmission.
    kasi kung mainshaft bearing e lahat ng gears sana ang ingay. kaso hindi in your case
    pero di bale, at least nasolve na rin problem.
    Apr 2008
    Quote Originally Posted by miked View Post
    Sinunod ko lang term sa casa but yes glad it's gone. :D
    Apr 2006
    My problem with our 2008 honda city A/T is there is loud vibration (garargal) in the left front wheel whenever i accelerate suddenly. Pag dahan dahan ang arangkada, wala naman. Could this be part of CVT problem that I read about this honda city model? Thanks in advance.
    Does the sound change with speed? Ugong sound? Or tick-tick sound? Sound changes with steering?
    Might be wheel bearing. Or it could be cv axle.
    CV Joint And CV Axle Problems - AutoZone Car Care - YouTube
    Apr 2006
    So far only on quick or sudden acceleration. Tnx.
    Jul 2017
    Hi Guys,
    Just want to check what can cause a whining noise when my car is accelerating fron 1st to 2nd gear. Sounds similar when in reverse. No noise in neutral. Changed release bearing but noise is still present. Car is Honda City 2004 MT.
    Thanks!
    when engine is idling, is there a difference in the sound of the engine/transmission if you press your clutch?
    if yes and you already change/checked ur pilot bearing, clutch lining, pressure plate and the noise is still present, you need to change the main shaft bearing.
    when changing the mainshaft bearing, you need to check the roller bearings of ur 1st and 2nd gear, this is the prmary reason if you hear noises in a specific gears. sometimes the is like a crying baby,lol
Whining Noise
