Results 11 to 20 of 21
- Apr 2008
- 99
October 25th, 2016 09:34 AM #11
October 25th, 2016 09:45 AM #12
October 25th, 2016 10:05 AM #13
1st and 2nd gears share the same synchronizer hub/sleeve.....
eto most likely ang may sira.....
chipped teeth on the synchro hub, worn synchro,........
bottomline, remove and disassemble the trans for better diagnosis.
- Apr 2008
- 99
November 7th, 2016 09:39 AM #15
ibig nyo po bang sabihin yung bearing ng input shaft? input shaft yung nakaconnect sa clutch disc
or yung bearing ng mainshaft which is nasa rear part ng transmission.
kasi kung mainshaft bearing e lahat ng gears sana ang ingay. kaso hindi in your case
pero di bale, at least nasolve na rin problem.
- Apr 2008
- 99
November 8th, 2016 12:06 PM #16
- Apr 2006
- 288
November 18th, 2016 04:23 PM #17My problem with our 2008 honda city A/T is there is loud vibration (garargal) in the left front wheel whenever i accelerate suddenly. Pag dahan dahan ang arangkada, wala naman. Could this be part of CVT problem that I read about this honda city model? Thanks in advance.
November 18th, 2016 04:40 PM #18
Does the sound change with speed? Ugong sound? Or tick-tick sound? Sound changes with steering?
Might be wheel bearing. Or it could be cv axle.
CV Joint And CV Axle Problems - AutoZone Car Care - YouTube
- Apr 2006
- 288
- Jul 2017
- 6
July 25th, 2017 11:12 AM #20when engine is idling, is there a difference in the sound of the engine/transmission if you press your clutch?
if yes and you already change/checked ur pilot bearing, clutch lining, pressure plate and the noise is still present, you need to change the main shaft bearing.
when changing the mainshaft bearing, you need to check the roller bearings of ur 1st and 2nd gear, this is the prmary reason if you hear noises in a specific gears. sometimes the is like a crying baby,lol
high idle RPM at engine start
