Quote Originally Posted by tonyboy View Post
Hi Guys,
Just want to check what can cause a whining noise when my car is accelerating fron 1st to 2nd gear. Sounds similar when in reverse. No noise in neutral. Changed release bearing but noise is still present. Car is Honda City 2004 MT.
Thanks!
when engine is idling, is there a difference in the sound of the engine/transmission if you press your clutch?
if yes and you already change/checked ur pilot bearing, clutch lining, pressure plate and the noise is still present, you need to change the main shaft bearing.
when changing the mainshaft bearing, you need to check the roller bearings of ur 1st and 2nd gear, this is the prmary reason if you hear noises in a specific gears. sometimes the is like a crying baby,lol
