Quote Originally Posted by tonyboy View Post
Replaced the transmission fluid 3 weeks ago prior to replacing the release bearing and clutch disc.
Prior to the oil change, walang whining noise whatsoever? If so, are you sure that the correct gear oil viscosity was used? Is the gear oil level correct?
