I upgraded my bulbs to 90/100watts and used it for around 2 years before . ok naman ang lens. make sure to use quality bulbs which has good UV coating para hindi mangitim ang lens. it will also be better to install a wiring kit. but this pales in comparison to an hid projector.
Were of the same fate brader. Nadale din front bumper ko same as yours sa high parking gutter. Pina estimate ko sa TMBC 2K daw repair of the front bumper. Wag ko na daw i claim sa insurance kasi halos ganun din participation fee at daming docs pa na requirements. 2 days to do the job. Pa repair ko nalang siguro pag dumating xmas bonus. Hahaha
Juat had my 1k km PMS sa toyota pasong tamo. Total bill P1745. I asked the SA kung pwede yung factory TVSS alarm pag arm/disarm tutunog din yung busina. Ngayon kasi nag flash lang ang signal light. Hindi daw pwede yun. For models 2005-2009 lang daw yun. Pero sa manual may instruction how to do it. Sa revo ko kasi pag arm/disarm may busina. At pag start pa lang lock na agad. I suppose pareho naman ang alarm nila. Any of you tried activating the answerback feature ng alarm?
can you check kung may 1 pc na busina sa may tabi ng air filter. eto kasi yung tumutunog for alarm answer back.
Go to other dealers and go straight to Parts and Accessories section and ask them to reconfigure your TVSS. Forget what your previous SA advise, usually the guy from the parts and accessories knows better.
In TMBC you can go check with the installer personnel directly, they have a workshop outside the building. it was on the side facing the creek and Roxas blvd.
We have older Innova's in our office 2005-2006 with horn enabled. Newer models have the horn feature disabled from the plant since most users don't want it enabled.
Thanks for the info. The SA did say that he asked the technicians and that they even tried activating it. Probably tinamad mag basa ng manual. Medyo mahaba ang procedure eh. Madaming pindutan ng buttons. Anyway will try your suggestion. I suppose TMBC is Toyota Manila Bay?
For AT, normally we just put the shift knob to 'D' and driveaway. I never or rarely use the '3, 2, L' transmission gear. Question is, may negative effects ba pag hindi ginagamit ung ibang transmission gear stated?
Magtanong lang sirs...AVANZA G 2006 ang unit ko
3 times na ko nagpapalit ng fuse ng Power Window ko the last 2 weeks...every time papalitan ko...hindi umaabot ng 1 week busted na agad fuse...kaninang umaga wala pang 30 minutes sira na uli kaagad ang fuse...
Ano po kaya sira ng electrical nun? I plan to bring the car sa Rey's Electrical sa Marikina...
Kindly advice po mga sirs...
TIA
What is the most economical speed to get the best FC for both Innova Gas and Diesel?
[QUOTE=SEALANDER;1848853]Just had my 1k km PMS sa toyota pasong tamo. Total bill P1745. I asked the SA kung pwede yung factory TVSS alarm pag arm/disarm tutunog din yung busina. Ngayon kasi nag flash lang ang signal light. Hindi daw pwede yun. For models 2005-2009 lang daw yun.
sabi ng SA ganun daw? di ba nya alam na unang lumabas ang facelifted model ng innova is 2009. bakit daw di pwede ang flash signal lights lang? sa G ko 2011 model sir signal lights lang when lock/unlock. di yata alam ni SA kung anu sinasabi nya. :D pero kung gusto mo sir tutunog yung busina, nababago yun. may i press ka lang sa master keys. sa owners manual makikita mo yun if preferred mo yung ma busina. pero i think mas ok na walang ganun, siglnal lights flashing na lang while lock/unlocking.![]()
The default signal for door locking - 1 flash signal light
The default signal for door unlocking - 2 flash signal light
It is written in the manual on how you could change the settings to customize your needs.
