Page 83 of 775 FirstFirst ... 337379808182838485868793133183 ... LastLast
Results 1,641 to 1,660 of 15487
    Jan 2008
    #1641
    Mga peeps, pansin ko lang sa stock Yokohama tires ng Innova, mahina ang grip. 3 months old Toyota Innova G yung sa akin.
    Oct 2011
    #1642
    Quote Originally Posted by josephm View Post
    Bridgestone ang akin. walang problema sa tire grip.
    Mar 2011
    #1643
    sana may EB ulit ang club before 2011 ends...
    #1644
    Hi guys. Kailan kaya lalabas sa atin to?
    Appearing in 2001, the 2KD-FTV is the 2nd generation of the KD series of engine with a smaller 2.5 L (2494 cm³) displacement.
    The displacement of this engine is based on the previous 2L engine. Bore remains the same 92 mm but stroke is increased to 93.8 mm. It has 16 valves and is a DOHC engine with a turbocharger and intercooler.
    It produces 101 horsepower (75 kW) at 3400 rpm and 191.7 ft·lbf (260 N·m) of torque at 1600-3600 rpm without an intercooler and 118 hp (88 kW) at 3400 rpm and 239.85 ft·lbf (325 N·m) of torque at 1600-3600 rpm for the intercooled version. Toyota Thailand, however, has updated the turbocharger to variable nozzle turbo (VNT) with intercooler. This increased the horsepower to 142 hp (106 kW) at 3400 rpm and torque to 343 Nm at 1600-2800rpm.[1]
    Compression ratio is 18.5:1. Redline of this engine is 4400 RPM. This engine also uses D-4D Common Rail (Common rail direct fuel injection ) technology. The only major changes from the 1KD-FTV to the 2KD-FTV was the bore and the stroke.
    This engine is used in the Toyota Hilux, Toyota Fortuner, Toyota Innova and Toyota Hiace. In some Central and South American countries, Toyota also offered this engine on the 2003-2006 4Runner in limited quantities. It has planned to be used in the sixth generation Toyota Kijang which will launched in 2012.
    Toyota KD engine - Wikipedia, the free encyclopedia
    Apr 2005
    #1645
    Sir what is your basis for this? On wet or dry road? Innova G din akin 1 month old.
    Oct 2011
    #1646
    Quote Originally Posted by amir1223 View Post
    sana sumama din mga new members.
    #1647
    hi fellow tsikoteers. patanong naman kung meron sa inyong may idea kung may lalabas na bagong innova? contemplating on buying an innova and maganda discounts ngayon. kaso baka may bagong lumabas luma kaagad yung sasakyan.
    Oct 2011
    #1648
    Quote Originally Posted by matty View Post
    If im not mistaken, next year na. mag nag post dito ung bagong Kijiang.
    #1649
    thanks for the reply. baka it's worth waiting for. sana first quarter ng 2012 lumabas. tahimik kasi sila kung kelan darating dito sa atin e. pahabol na din, medyo gulong gulo pa rin ako kahit binasa ko na yung d4d vs vvti na thread ng innova. ok na kaya yung d4d? parang mas practical kasi sya kasi matipid at mura diesel kaso parang nakakatakot yung nabasa ko sa issues ng d4d. tsaka may mga nakikita akong innova diesel na grabe ang usok.
    Jan 2010
    #1650
    maybe next year labas na yan...
    IMO yung current model ngayon ng innova ang pinakapogi.... same with fortuner at hilux... 2010 model...
    Oct 2011
    #1651
    hintayin mo na lang bro if i were you. ako din nagugulhan sa D4-D issues. observe proper pms of your innova na lang bro.
    #1652
    *Capsaul, depende sa tumitingin siguro. pero yup, maganda nga yung itsura ng 2010 model. although, sa nakita ko sa net, parang mas naging macho yung harap, parang mas litaw yung mga kanto. pero baka iba pag-actual na. kasi minsan nakakaloko ang pictures e.
    *Retz, mas ok nga siguro na antayin ko na lang. nakakainis nga e. parang lalo akong naguluhan nung binasa ko yung comparison thread hehe you cannot have it all nga. may pros and cons. depende na talaga siguro sa gagamit.
    Oct 2011
    #1653
    Pwede na ba Prestone brake fluid (dot 3) sa Innova?
    Oct 2011
    #1654
    Spotted an Innovaclubph vehicle sticker inside CCP complex earlier this evening. zcj 322.
    Mar 2011
    #1655
    Mga boss balak ko po sana Bumili ng mags for my innova J. 15inch po sana. mag tanung po lng sana ako ng size kc di ako familiar s size ng mags.Gusto ko po sana ung medyo mlapad kesa s stock rims. d2 po kc ako bibili s jeddah KSA kc mura daw d2 uwi ko dyan s atin. TY po s reply
    Feb 2011
    #1656
    yung ngayong model ang pinaka maganda. walang duda dun. maraming nagsabi na na yung ngayon ang bet kesa dun sa lalabas na bago. for me ngayon ka na bumili kasi innova pa din yan. pag labas nung bago, mag aantay ka pa ng 1 year siguro para maka discount dun. for sure pag labas nung bago walang ka discount discount yun tapos mahirap ang pagpili ng color ng unit for sure at pila yan, ma ba-badtrip ka lang. at for sure MAS MAHAL yun.
    RE sa paglabas: MAY 2012 ang alam kong lalabas yan kasabay nung new camry.
    RE D-4D issues: wala na yan ngayon alam ko. kasi iba na injection pump nung innova ngayon dun sa first model ng innova (2005-2008 models). alagaan mo lang fuel filter ng innova mo and you will not have any problems. D4D problems occur when the fuel filter is not being properly replaced and also proper PMS to your vehicle. that was said by my mechanic in toyota, a chief mechanic there actually. diesel din kasi yung sakin at sinabi nya mismo sakin panu yun mag o-occur.
    Feb 2011
    #1657
    mga pre, sa warranty, san best na casa mag claim? kasi sa cubao (dealer ko) palage walang stock kung anu i claim sa warranty, aantayin mo pa kung kelan deliver ng planta sa kanila, ka badtrip.
    ipa warranty ko kasi headlights and foglights ko. one time kasi nakita ko may moist sa gilid after an evening drive with rain, pero di na nangyari ulit. actually dati pa yun, ngayon ko lang balak i claim. sinabi ko sa toyota, sabi naman nila is picturan ko daw then ipakita sa kanila ang pic to claim the warranty kasi nung PMS ko ayaw mag moist kasi makulimlim at daytime so di naman need bukasan ang headlight. so ang sabi papalitan daw ang headlight and foglights ko ng bago pag napakitaan ko na ng picture.
    Jan 2008
    #1658
    Quote Originally Posted by SEALANDER View Post
    Hard cornering, dry road. Or maybe it's just my aggressive driving. Driving an Innova like driving a sedan
    Oct 2011
    #1659
    kaya naman pala.
    Dec 2009
    #1660
    Masters, matanong ko lang saan kaya nakakabili ng black stepboard for innova na kamukha ng sa montero? May nakita kasi ako bagay naman kay innova. Thanks for the reply.
Toyota Innova Owners & Discussions [continued 3]
