Page 642 of 775 FirstFirst ... 542592632638639640641642643644645646652692742 ... LastLast
Results 12,821 to 12,840 of 15487
    Jun 2009
    #12821
    Innova Gas 2009 E.
    Problem : Yung aircon pipe na connected sa rear evaporator. Curly po ito.
    Diagnosis : Brought to CeeJay. First have cleaned and leak test. Akala ko mga O-rings lang. pero bumalik din problema.
    Verdict : Need palitan yung read piping with Toyota part # 88710-0k550. mahal ng parts na ito.
    Help : Baka may similar cases na po kayo and nakuha pa sa remodyo or surplus parts.
    Salamat..
    Jun 2016
    #12822
    May prospect na ako kasi yung kawork ni father binebenta ung 2015 innova e mt dsl brown big grill running 17k palang for the price 550k. namomoblema sa amoy ng aircon.diniscourage namin na ibenta na kasi dpat AT binili nya kasi nextyear baka may excise na :D
    Jun 2009
    #12823
    Quote Originally Posted by troydl View Post
    Mga Sir,
    Where can i buy Toyota spare parts (preferably orig) such as air conditioner blower, side mirrors assembly here in mandaluyong, san juan or pasig?
    In Pasig, you can try MITCARS Auto Parts Center along Amang Rodriguez Ave., Santolan, Pasig. Katapat nila halos ang south supermarket.
    #12824
    Quote Originally Posted by ParticleX View Post
    anyone knows how to disassemble the front grille on a 2015? ayusin ko lang sana yung horn circuitry then hugasan na rin yung condenser, andami nang bugs kasi
    are you sure, hindi puedeng dukutin ang busina niyan, without removing the grille?
    baka puedeng kunin from the radiator's front?
    Sep 2006
    #12825
    medyo masikip pero kaya naman dukutin. nung kinabit ko yung bosch europa horns sa innova ko di ko na inalis yung grills. nag lagay pa ako ng additional harness and relay nun.
    Feb 2006
    #12826
    mga sir meron na po ba nakapag bleed ng brake fluid sa inyo po tapos palitan ng fluid mga magkano po inabot
    Apr 2010
    #12827
    i myself installed europas and a relay and kaya madukot. i have other plans though
    i managed to remove 5 push pins pero yung clips hugging the bumper ang hindi ko pa matanggal
    Dec 2007
    #12828
    Guys, need your opinion. One of the bolt stud (front left wheel) broke when a good samaritan helped my wife changed a flat tire. The stud broke during the removal so it must have been stressed out already (probably due to over tightening. Question is, is it safe to use the vehicle, bahay to school and vice versa lang naman until I get to replace the hub? Another question, is it required to replace both hubs, like you would replace a pair of tires? Thanks for the reply.
    #12829
    Quote Originally Posted by timo07 View Post
    the remaining four studs can pick up the slack, but only temporarily, as it is weakened by the absence of the fifth stud. it should hold, in an emergency, or just so i can bring the car home. but i'd have it repaired as soon as i can.
    most studs are replaceable, po.
    naka-turnilyo o naka-saksak sila sa hub, from behind.
    any decent shop can do it.
    i'd replace just what is broken, po. no need to replace or repair them by pairs.
    Dec 2007
    #12830
    Wow dr. d, thanks for the reply. I didn't know a broken stud can be replaced. Tawag na sana ako sa casa to check price. I'll ask my wife to refrain from using the car muna. Thanks sir!
    Aug 2012
    #12831
    Yes, wheel stud can be replaced. It is available in different lengths.
    Sent from my ASUS_Z010D using Tapatalk
    Dec 2007
    #12832
    Quote Originally Posted by red_one View Post
    Nice, thanks!
    May 2017
    #12833
    Quote Originally Posted by Trasher17 View Post
    Hi mga Sir. Kakabalik lang namin galing toyota casa sa alabang. Kasama sa recall ang innova namin. Innova G gas 2.0 2005. Pag lumabas ang airbag indicator it means palitin na ang clock spring. Libre lang po ang pagpagawa recall kasi. Warranty till 100,000km. Ang tinatakbo pa lang ng innova namin 78000km. Kaya pasok pa sa warranty.
    Sana makatulong po eto.
    Thanks Bro.
    Yung sa akin sound lang. Di nailaw ng matagal yung airbag indicator.
    Actually checking the airbag was supposed to be my 3rd work order pero parang na solved yung problema. Di na nag occur uli.
    First na ginawa ko was nag upgrade ng tire size to 205-70/R15 using Yokohama Geolandar series.
    Second was changed my engine oil to full synthetic.
    After those changes, di na nag occur ulit yung sound. Di ko alam kung dahil sa changes na ginawa ko pero inoobserbahan ko pa rin.
    I'll have the chance to verify if the unusual sound is gone paghahataw ulit sa expressway on the way North.
    Jun 2017
    #12834
    Quote Originally Posted by 94mitsukid View Post
    Hello. My friend is an innova owner. May kakilala ba kayo ng nagrerepaint kasi nasira na clearcoat ng sasakyan? Hood and roof ung nasira. Salamat!
    PAJ 4M40 MORE POWER!
    Yes po dito sa amin cabuyao laguna area po
    Jun 2017
    #12835
    Mineral oil pag ayaw mo synthetic mas mura. Pag wala naman problem sa tire and breaks mo wag mo muna pagalaw. 2 weeks ago nag pa 1k pms din ako change oil and filter lang. May separate thread yata sir para sa new innova dun ka na lang mag post next time. Thanks
    Sent from my SM-J500G using Tsikot Forums mobile app
    Sir/mam newbie po ako i have new innova 2017 mag 1k odo for change oil na din need ko po advice ninyo kung ano dapat lang ipagawa sa casa maraming salamat po
    Apr 2010
    #12836
    i need to disassemble the door panels to measure maxiumim allowable speaker depth, baka may steps kayo on how to unscrew/unclip them. front and rear doors sana
    Dec 2007
    #12837
    Remove the screws first, on the door opening latch (however you call it) and doon sa may recessed handle. Then carefully pry away the panel from the bottom, sides and middle portion to dislodge those plastic rivet thing from the metal panel. Lastly, lift the top portion of the panel from the door. Do not pry it away like you would the other portion. Nakasabit yung door panel. Hope this helps.
    Apr 2010
    #12838
    thanks, already disassembled the front door
    no idea how to remove the damn things though.... tried prying with a flat screwdriver
    Apr 2010
    #12839
    so riveted pala.i can do it pero this is too much work if onti lang naman price difference pagawa ko na lang
    Jun 2009
    #12840
    Quote Originally Posted by iyzburg View Post
    Attachment 34964
    Good day.. First Gen Innova owner here po.. Somewhere along the front pillar at the passenger side, may nagleak sa taas.. Dati po wala, pero last Tuesday, bigla nag-leak.. Ano po kaya dahilan.. (I highlighted with yellow where the leak appeared)
    Ganyan din ang innova 2005 model namin. Nagleleak pero na ondoy na siya. Sa 2010 at 2013 model namin wala naman ganyan. Ask ko lang nagpalit ka ba ng windshield? Baka yung rubber na itim sa may bubong ng innova may butas o di na sealant mabuti.
Toyota Innova Owners & Discussions [continued 3]
