Page 492 of 775 FirstFirst ... 392442482488489490491492493494495496502542592 ... LastLast
Results 9,821 to 9,840 of 15487
    Feb 2006
    #9821
    black po sir
    #9822
    Quote Originally Posted by shibby75 View Post
    Ganyan din front tires ko eversince bnew, mabilis maubos outer tread, ala naman problema sa camber, straight as arrow, no wiggle even at top speed.
    Rotate ko na lang every 5k, kada adjust ng rear brakes, then flip inside out the uneven wearing tires.
    Sana disk brakes rear ng innova ng dina kelangan adjust.
    napansin ko din itong front tire wear sa innova.so i guess its normal
    Jan 2014
    #9823
    Bros,- anyone here who was able to successfully mitigate the accelerated wear on the front tyres of our Innova?
    It still is a problem with our ride, even if I inflated the front tyres to 40psi... Don't want to go any higher than that, right now....
    “The measure of a man is what he does with power – LJIOHF!”
    Duterte for President of the Philippines in 2016!
    25.5K:cold:
    What tire brand do you use?
    I haven't experienced that but I'm sure I chnaged my tires twice already dealer yokohama- goodyear-goodyear every 60k kms.
    Let me check my Innova in the garage
    Jan 2014
    #9824
    Is the discoloration in the inside or outside of the headlights, bro?
    25.5K:cold:
    It depends bro it can be inside or outside
    If it's outside spary some degreaser first, the polish
    If it's in the inside you have to remove the lens
    Have you experienced yellowing on your innova's lens?
    #9825
    Quote Originally Posted by crosswind View Post
    The lens are still very clear bro... I guess because I park it under the shade almost all of the times(?).....
    Am still using the original Yokohama tyres.... Mileage is now 35KKm... Uneven wear is noticed in the next tyre groove just after the main(middle) one....
    25.5K:cold:
    #9826
    how is the lens removed, and how is it put back and still remain watertight?
    Aug 2012
    #9827
    You need to melt the adhesives by baking the headlight assembly in an oven, or using heat gun or hair dryer, or using hot water, etc. Then you can remove the lens and clean the inside. YouTube has several videos for this.
    It is best to use the same type of adhesive to put the lens back but most just use silicone sealant.
    For the adhesive, you can try to PM Gary of the HID Retrofit thread. He buys his adhesives from China. Maybe you can order a small quantity.
    #9828
    Quote Originally Posted by red_one View Post
    sounds difficult.. baka yung housing ang matunaw at ma-distort.. hindi na watertight...
    magkano bang bagong assembly na lang? heh heh.
    addendum: waddayouknow...? sulit has many advertised.. 4K average per piece..
    Aug 2014
    #9829
    Meron nabibili adhesive sa mga auto glass like aguila, nakaayos yung adhesive parang katol at parang pliable na asphalt ito.
    Heat gun din yata kailangan pag nag-apply ng adhesive.
    Feb 2006
    #9830
    mga sir ano po pwede gawin kapag naiwan yun susi sa loob nakasuksok pa rin po kc sa may manibela, eh nailock na po yun mga pinto nag iisa pa naman po remote ng alarm pati susi wala duplicate tsk tsk tsk baka po may makatulong innova j 2010 po yun sasakyan
    Aug 2013
    #9831
    25.5K:cold:
    check mo sir yung front shocks. ganyan din yung sakin.
    if ok naman yung shocks (walang leak), wheel alignment (Camber and Toe alignment) ang solution dyan.
    share ko lang yung ginagawa ko. currently running 18" wheels ako with 235/50 tires. naka -0.5 degrees of camber ako sa harap. going 2 years na, wala akong wear problem sa front tires. replaced front shocks na din ako kasi nasira agad at 10,000 kms. bali nagpa re-tight ako ng suspension parts plus wheel alignment.
    Aug 2012
    #9832
    Gary has been opening and resealing headlights for his HID retrofit projects for years now. Hindi naman natutunaw, distort or nagli-leak ng water.
    If P4k sa OLX, 2 pcs headlights will then be P8k. You can open, clean and re-seal both headlights already at less than P1k, or kahit abutin pa ng P2k, it is still way cheaper and may matira ka pang materials for yourself.
    Oct 2009
    #9833
    Balak ko bumili ng DLAA fog.naninilaw ba ito katagalan?
    Balak ko pa seal sa kanya kung tumatanggap sya kasi usually ata prob ng dlaa nag momoist.
    Aug 2012
    #9834
    Di mo na need ipa-reseal yan. Bili ka ng silicone sealant at pahiraman sa paligid at sugpungan bago mo install sa sasakyan mo.
    Lahat ng plastic, pwede manilaw sa katagalan dahil sa UV rays. Pahiran mo ng wax or sealant every few months para protection from UV rays.
    Aug 2014
    #9835
    Quote Originally Posted by jovz View Post
    Hindi siguro oem remote mo,
    May 2 option ka may serial number susi ng innova pagawa ka sa casa kung alam mo number ng susi, expensive ito
    Or tumawag ka ng locksmith sandali lang yan.
    Feb 2006
    #9836
    Quote Originally Posted by vix View Post
    sa casa din po nagpakabit ng alarm, pero ok na po sir kinawang lang ng konti yun pinto tapos saka sinuksok yun kawad para masungkit yun pinakabukasan ng pinto sa loob thanks po
    Feb 2006
    #9837
    Oct 2009
    #9838
    Ah talaga sir.pwede pala pahiran ng wax mga lens ng sasakyan? Wag lang sa windows no?
    Aug 2012
    #9839
    Quote Originally Posted by harold13 View Post
    You can apply wax or sealant on windshield and windows. I do with my car. Ayaw mo ba nun, nag-bi-bead rin ang windows mo kapag umulan. Madali pa linisin.
    Oct 2009
    #9840
    Ah ok.car wax pwede no like Megs white wax?
    Hindi kona pala kailangan pahiran ng rain repellant mga bintana kung ganun. Hehe.
Toyota Innova Owners & Discussions [continued 3]
