Page 491 of 775 FirstFirst ... 391441481487488489490491492493494495501541591 ... LastLast
Results 9,801 to 9,820 of 15487
    #9801
    Sorry, double post....
    “The measure of a man is what he does with power – LJIOHF!”
    Duterte for President of the Philippines in 2016!
    25.5K:cold:
    Nov 2014
    #9802
    Quote Originally Posted by frequenzy View Post
    3yrs ko ng gamit yung Unioil Diesel, no issues naman. yung isang kasama ko na may bagong Innova, Unioil na rin ang gamit coming from Shell, ok din, parang mas tahimik daw compared sa Shell. FC ko for city driving is 10km/l.
    Thanks *frequency and *CVT for the replies. Although I prefer the low-sulfur ng Euro4 diesel fuel for environmental reasons, nag-aalangan pa rin ako sa small oil players lalo na sa fuel handling and specially after reading through the dirty fuel issues. But after reading your comments, try ko rin, siguro mixed with my current fuel from Caltex.
    BTW, I'm also getting 10km/l sa city driving (usually hatid-sundo sa mga bata, 10km / trip from UP-SM North-UP. Best FC ko pa lang ay 11.1 km/l from QC to Porac (not tipid mode), same with QC to Baras via Antipolo. Paano ba ang tipid mode? Gusto ko itaas sa 13km/l sana sa pagpunta namin sa Tagaytay this weekend.
    Sep 2006
    #9803
    my innova is almost 3 years old. still on the original tires, but they look evenly worn to me. did you have your camber/caster checked? also bushings, etc.
    Oct 2009
    #9804
    Baka needs camber and balancing.
    Jun 2006
    #9805
    Ganyan din front tires ko eversince bnew, mabilis maubos outer tread, ala naman problema sa camber, straight as arrow, no wiggle even at top speed.
    Rotate ko na lang every 5k, kada adjust ng rear brakes, then flip inside out the uneven wearing tires.
    Sana disk brakes rear ng innova ng dina kelangan adjust.
    #9806
    Quote Originally Posted by shibby75 View Post
    is it possible, it is the way you drive, sir?
    making very lively use of the steering wheel might be contributing to the front tires' wear..
    or all that bouncing around wears out the front tires faster..
    i remember years ago.. mitsu pick-up owners used to complain how fast their front tires wore out..
    Jun 2006
    #9807
    Yes, naisip ko din na baka dahil sa over use ako ng manibela. Yung tipong pag liko eh kahit hindi klangan isagad, naisasagad ko ang manibela sa slow turns.
    #9808
    RWD ang Innova kasi,- and so, high speed curves put heavy toll on the front tyres (dahil passive sila)....
    Yup,- more frequent tyre rotation ang katapat....
    �The measure of a man is what he does with power � LJIOHF!�
    25.5K:cold:
    Jan 2011
    #9809
    [COLOR="#008080"]
    Bros,- anyone here who was able to successfully mitigate the accelerated wear on the front tyres of our Innova?
    It still is a problem with our ride, even if I inflated the front tyres to 40psi... Don't want to go any higher than that, right now....
    Akala ko ako lang may problema nito with my 2011 Innova at 23K mileage. Na noticed ko to last month, pudpod yung outer thread parehas sa front tire then dinala ko sa talyer and they adjusted yung camber. But may na noticed akong unusual after that, parang naging medyo malikot manibela ko specially kapag rough road. Parang pakiramdam ko kapag nalubak ng konti yung front tire gumagalaw din yun manibela.
    Dec 2011
    #9810
    *2rm
    I'm curious, how did your talyer adjusted the camber? Because, it seems that a new issue came up after the adjustment. Better go back and have it check again or visit an autoshop that specialized in wheel alignment (ie, servitek).
    For your guidance folks:
    Wheel Alignment Explained - What is camber, caster and toe? - Yospeed
    Cheers!
    Dec 2011
    #9811
    *2rm
    Cheers!
    Jul 2013
    #9812
    Wear pattern is on the side, bro,- just outside the middle and its adjacent canal..... It looks like the Innova has this issue, based on few benchmarkings that I did....
    How about yours, bro... Have you experienced them?.... Thanks!
    25.5K:cold:
    I've had worse issue with ours. As in pudpod ang outer thread. Serious camber and alignment issues out of the dealership. Of course I was not able to detect it until the tires are spent because there were literally no steering issues back then. Walang kabig or wiggle. Yung uneven tire wear llang ang indication.
    I do not know if it is possible but my friend of mine said that to allow the wheels align and straighten by itself after steering, a bit of camber misalignment is present during turning.
    Jul 2013
    #9813
    Guys I need some advice.
    Sa mga naka fully synthetic oil, anung change oil interval niyo?
    Naka fully synthetic kasi ako ngayon at 5,000 kms (6 months) na ang tinatakbo.
    Hindi naman severe driving condition sa amin sa Laguna.
    Ok ba na i-extend pa ito to 10,000kms (12 months) pero papalitan ko oil filter now?
    BTW, mukhang hindi na muna ako babalik ng casa kahit tama ang sabi nila. Mejo namamahalan kasi ako sa quation nila.
    Jul 2013
    #9814
    Double post.
    Jun 2009
    #9815
    hi guys, bought a innova 2012. noticed the front is tilted to the driver side. causing the rear right to be lifted. our maybe the rear right is to high that the front left is lower. Anybody encountered this? ALready replaced 4 shocks. please help. Thanks
    #9816
    Quote Originally Posted by lucid21 View Post
    Hindi kaya nagka-major accident iyan at nabengkong ang pang-ilalim?
    25.5K:cold:
    #9817
    Quote Originally Posted by Lew_Alcindor View Post
    Bro.,- Fully synthetic oil is good for 10,000 Km.
    Change the oil filter after 5,000 Km.
    Dagdag oil lang ulit....
    You're good to go....
    25.5K:cold:
    Feb 2006
    #9818
    ano po kaya pwedeng pantanggal nun gasgas sa side mirror, nasabitan po kasi ng side mirror din nun nakasabit parang guhit po eh
    Jan 2014
    #9819
    Quote Originally Posted by jovz View Post
    Black plastic or body color mirrors?
    Jan 2014
    #9820
    double post
Toyota Innova Owners & Discussions [continued 3]
