Page 446 of 775 FirstFirst ... 346396436442443444445446447448449450456496546 ... LastLast
Results 8,901 to 8,920 of 15487
    #8901
    520/pcs lang ang denso iridiumfor innova. Sobrang mahal sa casa.
    Sent from my Nexus 7 using Tapatalk 2
    Oct 2013
    #8902
    parang ang mahal sa 900 pesos eahc, tanda ko around 600 lang each kuha ko sa denso.
    Jan 2013
    #8903
    Quote Originally Posted by vvti2.0 View Post
    Oo sir mahal talaga kaso ayaw nila ikabit kung magdadala ako.. d bale ok lang sakin kse after 50k ba o 100k km na ako magpapalit ng spark plug tsaka meron na naman akong 12% discount on all parts and labor every pms.. at least intact pa rin warranty ko at excellent naman ang service nila so far.. binawi ko na lang sa kape at masahe sa lazy boy na upuan nila..
    Apr 2009
    #8904
    Guys share ko lang. Yung innova ko ng dsl 2012 model umilaw na yung para sa fuel filter. 25k palang ODO ko. Dinala ko sa casa sabi nila need na palitan yung fuel filter. Sana maging okay na after. Petron kasi ang gamit ko, sabi nila ang pinaka malinis daw ng diesel ngayon is caltex. Meron na po ba naka encounter sa inyo na umilaw na kagad yung sa fuel filter at low milaege?
    #8905
    Quote Originally Posted by terio2028 View Post
    try to shift to caltex, seaoil, or unioil if possible.
    #8906
    i did.
    i pumped the filter to rid of the water, as described in the manual. light did not turn off.
    i replaced the filter. light did not turn off.
    i replaced the entire assembly. light turned off.
    then i hear from someone here, that there is a way to manipulate the car, so's the light turns off without having to change the assembly.. i just forget how...
    i hope you can access the instructions and save yourself 2.5K..
    #8907
    Ano icon sa gauge for the fuel filter? can anyone post a picture? thanks!
    #8908
    i'm not too computer-savvy, so i can't post the picture.
    but mine is in the right lower corner of the gauge cluster, beside the fuel needle gauge. it's a gas pump figure with two rows of dots under it..
    the manual says it all, sir.
    #8909
    Lower right corner... Heto ba?
    “Familiarity breeds awe”
    23.6K:hiya2:
    #8910
    23.6K:hiya2:
    ah! AT pala yan.. if yours is similar to my MT....
    low fuel level yata yan, sir.
    the water-in-fuel filter icon is similar, but it has two rows of dots under it, simulating a filter or sieve.. perhaps you can see it if you shine a bright flashlight onto the surface of the gauge cluster.
    it should be to the right of the fuel gauge.
    #8911
    ^Boss CVT low fuel warning yan diba?
    #8912
    A/T rin saken, never ko pa nakita yung tinutukoy mo
    #8913
    i have an idea...
    google it,sir. innova fuel filter icon..
    #8914
    and i hope you never do.... bad news if it lights up.. i-ilaw lang kasi yan kapag ma-contaminate yung fuel mo ng tubig.. or kung ma-block na si filter.
    #8915
    Pero im glad meron pala ganyan na warning.
    Googled it BTW
    #8916
    ^^^ Yup, should be it...
    Wala malamang iyan sa gasoline variants...
    23.6K:hiya2:
    #8917
    23.6K:hiya2:
    Yup mine is gas also, never ko pa nakita yan umilaw i mean prior to engine start all the icons is umiilaw diba? wala talaga.
    Oct 2013
    #8918
    wala yan gas...
    Jan 2013
    #8919
    Hello tsikoters.. tanong lang po..
    yung memorandum ba ng LTO na nagbabawal sa mga plate cover or any plate accessories ay sakop din pati yung mga lumang plaka o para lang yun sa mga bagong version ng license plates?
    Salamat po..
    Oct 2013
    #8920
    lahat sakop, unless otherwise magrelease sila ng memo na para sa new plates lang yun..
Toyota Innova Owners & Discussions [continued 3]
